By Axe
#47591
A simple teapot, modeled in Rhino.
Rhinoll 0.6.1, Maxwell Beta 1.2.2
15 hrs, SL 15.
Slight De-Noising in Photoshop.
Athlon 64 FX-55, 2.6 GHz, 1 Gig RAM. ATI FireGL V7100 256 Mb
I notice the areas that were still noisy after so long rendering were those lit primarily by indirect reflected light.
Is it a better strategy to use more lights and higher shutter speeds at the risk of blowing out the image with too much light, vs less light and lower shutter speeds, but better control over shadows???
I know it's simple, but C&C are always welcome.
Axe
and another view:
By Mattia Sullini
#47637
Sorry to bother you for questions different than the quality of your images (that are in any case far boyond my capabilities with maxwell at present state), i9 would really like to know if you used a plugin with photoshop or just blurred a bit your image.
Thanx anyway! :wink:
By RonB
#47787
Very nicely done! Excellant modeling, especially the handle attachments to the body, looks like it really should with the glaze smoothing over the joint...the pot has a beautiful form also. The only thing that stops it for me is the texture of the handle itself, don't know what it's supposed to be but it looks like cheap plastic. Doesn't fit with the rest of the pot to my eye...perhaps a realistic bamboo might be better.
Cheers, Ron
By x_site
#47894
:: looks like the one in my local chinese restaurant! ::
By Axe
#47992
@Mattia: I just selected the areas that had too much noise and ran the "Median" filter to smooth it out a bit.
@Ron: Thanks for the comments. I'll have to UV map the handle and try a photo-real bamboo texture on it. That and a HDRI sky dome when I get the chance.
@X-Site: Thanks! I love how realistic Maxwell renders without having to try too hard!
Axe
By DELETED
#48072
DELETED
By Axe
#48290
Just wait until I add the rocket pods and gatling guns! New cybernetic attack teapot!
By iker
#48317
I love it Axe!
Can you share your light settings? (emitter/s position, energy, dimensions, camera settings, etc...?) :D
By Axe
#48379
Thanks Iker,
For reference of scale: the teapot itself is 14cm in diameter.
Lights:
Main light: 1cm x 1 cm, just to the left of the camera, approx same height as camera, 30 cm from teapot. D65, 750 Power.
Secondary light: 1 cm x 1 cm, close to the floor, angled up. to the right and slightly to the front of the teapot, also 30 cm away. D65, 500 power.
1 large (7 cm x 7 cm) behind and to the left of the teapot, 50 cm above the teapot, angled down. D65, 100 power. This is a soft fill light to cut the harsh shadows and give a little rim enhancement.
Camera: 50mm, about 30 cm away. ss 100, f-stop 32 (I may have changed the shutter a bit during the render). ISO 100.
Scene: Everything is enclosed in a rounded-ended cylinder 85 cm diameter, 60 cm high.
No environment/sky/sun.
Hope this is clear!
Axe
By iker
#48381
Thanks so much Axe! Great explanation! :D
