By Becco_UK
#47044
I like the Maxwell material you have made.
What are the dark bits around the edge of the sphere? I have noticed these dark edges around some objects in some of my tests/scenes. Are they something to do with the Cinema4D plugin phong problem not being completly fixed yet?
By DELETED
#47048
DELETED
By Tyrone Marshall
#47097
andrewsweet wrote:The dark bit's are because your model is low-res! use hi-res meshes and all will be fine!
A
Thanks Andrew, that is all a part of Maxwell Render's physically accuracy. My sphere is visually fine (subdivided) but with this render engine, it is not enough and the black points as you stated are the points of the faces.
By Tyrone Marshall
#47098
Becco_UK wrote:I like the Maxwell material you have made.
Thanks Becco, I will post some settings later on for this one. My sphere is not as subdivided as it should be.
By x_site
#47434
:: what's the material settings?... it is looking good! ::
