By j_petrucci
#44647
well, render the image at a bigger resolution then downscale, or use Neat Image to denoise or... leave Maxwell more time to work! :wink:
consider that dielectrics and physical sky introduce more noise than diffuse materials and standard emitters... :wink:
By Micha
#44762
... double size rendering in the same time -> denoise -> downscale. But, with caustics it should be a problem, because some caustic effects need a high SL count and in double size mode it need much more time to get the same SL.
