By Ric_535
#43806
i dont know the answer but ive seen this (not quite so bad) on other peoples co-op renderings - i would like to hear of a solution or a bug fix soon as i want to start doing my own co-op renderings
By Maxer
#43830
Level 5 looked real good but I don't know what's going on with level 15. I did my own test yesterday using 5 duals and compared it to the same image rendered on one dual and the results were the cooperative rendered image was worse after 15 hours. There is something definatley wrong with cooperative rendering but NL hasen't said anyting about it yet.
By Renato Lemus
#43890
this looks like a dispersion problem with coop rendering
By Para
#43955
Looks like the noise escaped from dielectric material to everywhere else in the scene :P
By psanitra
#44205
With all the power you have in the mashines, how it`s possible that you blue glasses are levitating above the table :shock:
Do a little step from the tiles to the green area, it will look much better and change the texture to something more detail...
