Everything related to Studio
#401903
I launched a render from Studio and have the MR screen on the second monitor, then adjusted some of the menu tabs to allow the render window a larger area and moved the ML tab to the bottom of the screen and it disappeared! It's still ticked (on) in the Window pull-down menu and moving MR to the first monitor doesn't restore the ML tab. Turning ML off and back on also doesn't restore it. Does anyone know how to restore an open menu tab that is off screen?
Thanks.
#401904
Ok found how to restore them. Select the MR window so it's active, press the Alt and Spacebar to open a small window then pick move and then use the keyboard arrow keys to navigate the menu back so it can be picked using the mouse and re-docked into the main MR window. Apparently, an issue when dual monitors are newly set up.
Thank you for the excellent reply, but unfortunate[…]
I still use Maxwell daily but every image goes thr[…]
