By ki_cz
#401472
Hi all,
I'm having trouble replicating this with maxwell:
The material is smooth on the outside, but the only way I can realistically replicate the increasing blurriness with distance is using the roughness parameter, which then detracts from the environmental reflections, although I can get close, it emulates more frosted glass than what is in the attachment.
I can get close with only scattering, but the edges of the leaves are too 'sharp' ... is there any way to achieve this kind of blurriness without roughness?
By ki_cz
#401476
Ok, well, after some experimentation I came up with something close, but I doubt it's the best way to do it.
I basically doubled the material on the backface of the glass box (by giving it a separate material ID), and it's much closer.
I'll post some of the results as they get clean enough so people can get an idea of what I meant.
By CDRDA
#401611
ki_cz wrote:
Sat Sep 03, 2022 10:52 am
Could you not add a coating to the material with a nm thickness that reflects white? That way you should be able to keep your reflections, whilst having control over roughness on the material underneath separately.
By Forum Moderator
#401628
Hello,
Adding a shiny layer in additive mode could help with that (actually a button was added at the bottom of the material editor to easily create shiny layers).
In this material, I'm using a shiny layer in normal mode over a rough transparent layer but it can work too:
Vidrio al acido 08 + reflejo.mxm
I'm not completely sure it is exactly the same material I used in these images, but should be close:
I hope it helps.
Best regards,
Fernando
