#400964
I'm trying to replace the MaxwellScatter setting from one object to another one by pymaxwell, but it just doesn't work. Could someone help me or point me in the right direction? I'm using pymaxwell4.
from pymaxwell4 import *
def replaceScatterSetting():
filepath = "C:/Users/twong/Desktop/test.mxs"
replaceDict = {'FloorA_old': 'FloorA_new', 'FloorB_old': 'FloorB_new'}
scene = Cmaxwell(mwcallback)
scene.readMXS(filepath)
for a in replaceDict:
objOld = scene.getObject(a)
objnew = scene.getObject(replaceDict[a])
if objOld.hasGeometryModifiers()[0]: # True = have Modifiers.
modifyQty = objOld.getGeometryModifierExtensionsNumber()[0] # check how many Modifiers in the object.
for i in range(modifyQty): # check Modifiers ono by one.
extData = objOld.getGeometryModifierExtensionParamsAtIndex(i)[0]
if extData.getFloat('Density')[1]: # Ture = MaxwellScatter
print('MaxwellScatter found')
scatter_Object = extData.getString('Object')
scatter_ObjectID = extData.getByte('Inherit ObjectID')
scatter_Density = extData.getFloat('Density')
scatter_DensityMap = extData.getTextureMap('Density Map')[0]
scatter_Overlapped = extData.getByte('Remove Overlapped')
scatter_Seed = extData.getUInt('Seed')
scatter_Scale_X = extData.getFloat('Scale X')
scatter_Scale_Y = extData.getFloat('Scale Y')
scatter_Scale_Z = extData.getFloat('Scale Z')
scatter_ScaleMap = extData.getTextureMap('Scale Map')[0]
scatter_UniformScale = extData.getByte('Uniform Scale')
scatter_Scale_Xvar = extData.getFloat('Scale X Variation')
scatter_Scale_Yvar = extData.getFloat('Scale Y Variation')
scatter_Scale_Zvar = extData.getFloat('Scale Z Variation')
scatter_Rotate_X = extData.getFloat('Rotation X')
scatter_Rotate_Y = extData.getFloat('Rotation Y')
scatter_Rotate_Z = extData.getFloat('Rotation Z')
scatter_RotateMap = extData.getTextureMap('Rotation Map')[0]
scatter_Rotate_Xvar = extData.getFloat('Rotation X Variation')
scatter_Rotate_Yvar = extData.getFloat('Rotation Y Variation')
scatter_Rotate_Zvar = extData.getFloat('Rotation Z Variation')
scatter_DirectionY = extData.getFloat('Direction Type')
scatter_LOD = extData.getByte('Enable LOD')
scatter_LOD_MinDist = extData.getFloat('LOD Min Distance')
scatter_LOD_MaxDist = extData.getFloat('LOD Max Distance')
scatter_LOD_MaxDist_Density = extData.getFloat('LOD Max Distance Density')
scatter_DirectionType = extData.getFloat('Direction Type')
scatter_InitialAngle = extData.getFloat('Initial Angle')
scatter_InitialAngVar = extData.getFloat('Initial Angle Variation')
scatter_InitialAngleMap = extData.getTextureMap('Initial Angle Map')[0]
scatter_DisplayPercent = extData.getUInt('Display Percent')
scatter_DisplayMaxIns = extData.getUInt('Display Max. Instances')
print('copy setting to new object')
extManger = CextensionManager.instance()
extManger.loadAllExtensions()
scatterExt = extManger.createDefaultGeometryModifierExtension('MaxwellScatter')
scatterExtData = scatterExt.getExtensionData()
scatterExtData.setString('Object', scatter_Object[0])
scatterExtData.setByte('Inherit ObjectID', scatter_ObjectID[0])
scatterExtData.setFloat('Density', scatter_Density[0])
scatterExtData.setTextureMap('Density Map', scatter_DensityMap)
scatterExtData.setUInt('Seed', scatter_Seed[0])
scatterExtData.setByte('Remove Overlapped', scatter_Overlapped[0])
scatterExtData.setFloat('Scale X', scatter_Scale_X[0])
scatterExtData.setFloat('Scale Y', scatter_Scale_Y[0])
scatterExtData.setFloat('Scale Z', scatter_Scale_Z[0])
scatterExtData.setTextureMap('Scale Map', scatter_ScaleMap)
scatterExtData.setFloat('Scale X Variation', scatter_Scale_Xvar[0])
scatterExtData.setFloat('Scale Y Variation', scatter_Scale_Yvar[0])
scatterExtData.setFloat('Scale Z Variation', scatter_Scale_Zvar[0])
scatterExtData.setByte('Uniform Scale', scatter_UniformScale[0])
scatterExtData.setFloat('Rotation X', scatter_Rotate_X[0])
scatterExtData.setFloat('Rotation Y', scatter_Rotate_Y[0])
scatterExtData.setFloat('Rotation Z', scatter_Rotate_Z[0])
scatterExtData.setTextureMap('Rotation Map', scatter_RotateMap)
scatterExtData.setFloat('Rotation X Variation', scatter_Rotate_Xvar[0])
scatterExtData.setFloat('Rotation Y Variation', scatter_Rotate_Yvar[0])
scatterExtData.setFloat('Rotation Z Variation', scatter_Rotate_Zvar[0])
scatterExtData.setUInt('Direction Type', int(scatter_DirectionY[0]))
scatterExtData.setByte('Enable LOD', scatter_LOD[0])
scatterExtData.setFloat('LOD Min Distance', scatter_LOD_MinDist[0])
scatterExtData.setFloat('LOD Max Distance', scatter_LOD_MaxDist[0])
scatterExtData.setFloat('LOD Max Distance Density', scatter_LOD_MaxDist_Density[0])
scatterExtData.setFloat('Direction Type', scatter_DirectionType[0])
scatterExtData.setFloat('Initial Angle', scatter_InitialAngle[0])
scatterExtData.setFloat('Initial Angle Variation', scatter_InitialAngVar[0])
scatterExtData.setTextureMap('Initial Angle Map', scatter_InitialAngleMap)
scatterExtData.setUInt('Display Percent', scatter_DisplayPercent[0])
scatterExtData.setUInt('Display Max. Blades', scatter_DisplayMaxIns[0])
objnew.applyGeometryModifierExtension(scatterExtData)
scene.writeMXS('C:/Users/twong/Desktop/output.mxs')
#400965
Hi, I tried your script in Maxwell 4.2.0.3 on Windows and it added a new MaxwellScatter modifier to FloorA_new and I could see that it had a 'Density' of 10 (same as the old) so I think your code works
BUT , pymaxwell.exe crashed constantly until I removed FloorB from your dictionary. I don't know why but I suspect the problem is pymaxwell.exe and not your code.
I would also move CextensionManager.instance() and loadAllExtensions() outside your loop since it only needs to run once.
Sorry I couldn't be more helpful.
#400966
Hi Harvey, I moved it outside of the loop as your advice, it doesn't crash anymore in my editor (PyCharm) and saved successfully, but it crashed when I open the result mxs file in Studio, I can see the materials but no objects and then stop working.
# ---- move outside here
#400973
I was able to run the script with maxwell4 if I just did FloorA and removed FloorB from the dictionary and in both 4 and 5 FloorA_new just got a second MaxwellScatter modifier added and no error. So no the loop works fine in 4/5, just 4 crashes if it loops over a second object or succeeds and makes a corrupt .mxs file that crashes on load.
