By David Henderson
#400945
Hello, I'm new to this forum. I have been running Maxwell for FormZ on an older Mac Pro, 2009. Would like to install a GPU card, but I can't figure out what is compatible with this Mac. I'm running OS 10.13.6. Any help would be greatly appreciated!!
Thanks
Dave
By Matteo Villa
#400949
https://everymac.com/systems/apple/mac_ ... yport.html
Here you can find an old tech link with some aftermarket compatible list of GPUs you could try.
https://www.youtube.com/watch?v=UoV4I-FlYdw
GPU Upgrade for Early 2009 Mac Pro (Radeon RX560, RX580)
If i find something more specific i will upgrade the reply.
Good luck with your upgrade.
ps: remember Maxwell Render use CUDA cores for GPU RENDERING, so is better stick to Nvidia.
By David Henderson
#400950
Thanks for the response! I did stumble on that site, and found an Nvidia Geforce GTX Titan. Hopefully it will work.....Surprising how many different boards there are, and how few are compatible.
Regular emitter vs. IES emitter
Why is a regular LED emitter with the same lumen o[…]
Nice work! Thank you for the time and effort you […]
Agate-type crystal / SSS
Hi guys, Thanks for the suggestions, once I come […]
Hello Mark, The easiest way would be to load t[…]
