By Forum Moderator
#400568
Hello Seguier,
Currently, there is no smoothing option, although you should be able to control the smoothing using Rhino options.
Regarding the light options, Maxwell will take into account the color and intensity of the Rhino lights and, depending on the light type you use, it will show different options.
You can also use the lights by material.
Please, check this link from the documentation for more information: https://nextlimitsupport.atlassian.net/ ... ell+Lights
Regarding Grasshopper, the last time I checked, we had to add some options to Grasshopper (like an additional plugin for it). Maybe, with the recent changes, it has become easier, but I will check again as I understand it is very powerful.
Thank you!
Fernando
