By Alexander Kuhnert - Mon May 11, 2020 7:50 pm
#399742
Hello everyone, we wanted to install the new Maxwell 5 today and provide the licenses via our existing RLM server, which already works fine for the Maxwell 4 licenses. Unfortunately that did not work...
1st problem:
For version 5 and 4 we have two different .lic files that have the same name (maxwell_archicad.lic). These cannot be located together in the same folder (Users / Shared / NextLimit / rlm_nl / Licenses). We have then created a subfolder "/ v5" to store the .lic file for version 5 there (as an interpretation of Fernando Tella´s post regarding the changes in the rlm license files location) . Maxwell does not find this folder in the activation process.
The name of the new .lic file was assigned during the activation process on the Portal / Nextlimit page. Can you rename these files? Or is there another way to place the new license file for version 5 side by side with the v4 licenses there?
2nd problem:
The attempt to place the license on the RLM server (on the remote computer) via the license activator also failed. You can start the login on the remote computer and enter our login details for the Nextlimit portal and the activation key. But then it says: Connection Error! Cannot validate license. Please visit our support site ....
3rd problem:
Do we need to set up a new RLM Server since there is a new installer in der V5 package that we downloaded to install the Maxwell 5 engine and plugin?
4th problem:
We want to use both mac and pc clients with the same rlm server. Are there any special advices for the host ID name system ? Right now we use the server only with mac computers and use the IP address system (numeric xxx.xxx.x.xx). But if we want to access the RLM hosting mac from the new pc computers we have to enter the MAC-address since the IP address does not work....
Best Alex
1st problem:
2nd problem:
3rd problem:
4th problem:
Best Alex
