#399611
Hey,
Making changes to the render porperties such as SL or output channels does not seem to have any effect. E.g. if I check MaterialId under "Output" and render I still only get main channel and when I go back to render properties the box is unchecked. Same goes for all options.
Has anyone else experienced this?
Workaround is to make changes directly in Maxwell once the render has started.
/Björn
#399691
Hello Björn,
Are you maybe setting those options from the Document Properties window? I would try to set them in the Renderer panel instead. I'm not sure right now but, if I'm not wrong, there were some issues storing the settings from the floating windows.
Also, as a general rule, I would try to keep Rhino up to date, as they also fix tings in the SDK that could be affecting the plugin behavior.
Does this method work better?
Best,
Fernando
Hi ki_cz, this is my attempt with another engine,[…]
Great Thx for the workaround and replies! Cheers.
Hi Artem, I think Your cream material is too glos[…]
Pricing
In the end, I have upgraded to 5.1. Even with the […]
