By mjcherry
#399610
Looking at doing some new promo pieces and am just assembling some concepts now. I would like to do something similar to this, perhaps, but not sure how I would go about rendering it. Thoughts are welcome!
By Max
#399613
i would probably split the render in 2, and make 2 separate renders.
- first one just an ocean with the upper part of the iceberg, you can not see trough the water
- second one, the iceberg as a whole with no water
might want to mask per object ID.
then composite everything in photoshop :)
By Mark Bell
#399617
This isn't the type of work my office would do, but at a guess:
1. model the iceberg as you want it to look with correct materials,
2. model a full depth rectangle for the ocean with the iceberg inside it,
3. use Realflow (NL) ocean or source a good ocean/water material off the Maxwell Materials site,
4. a second plane or 3D slab element closer to the camera with ocean/water applied may also be needed to give the underwater depth appearance?
5. use some artificial lighting to uplight the base etc.
I think the key is to get the depth effect in the water including the surface ripples. It will be interesting to see how you make this work.
By Mark Bell
#399618
another item: the rectangle/3D slab for the ocean may also need another 3D element wrapped around it and set to a dark material to prevent light extending to the lower depths to simulate the darkness further down?
