#398862
stupid me wanted to play with the demo of 5. now for some reason 4 is not licensed anymore. license files gone from program data/next limit/maxwell folder. license activator says it cannot activate my license no matter the fact I input correct data (email, password, serial...). what can be done ?!
also disabling firewall not working.
#398865
Hello,
You can always download the license files from your account at the portal.
You only have to put them in this folder:
C:\ProgramData\Next Limit\Maxwell\licenses
Best,
Fernando
#398870
so i am confused. What do i have to do to try Maxwell 5 demo?
because when i install it and launch the studio it says its not activated, then it let me pick "try demo" but after i select the demo mode the software opens up and it doesnt let me render nor switch to Gpu saying its not licensed.
#398879
Forum Moderator wrote:
Mon Nov 04, 2019 5:06 pm
Hello,
Best,
Fernando
thanks man that fixed it !! may I suggest writing to all ppl that want to try the demo to keep a backup of their license first....
#398881
Max wrote:
Mon Nov 04, 2019 6:55 pm
If it says no GPU licensed it usually doesn't have any license at all, not even demo. Try to restart maxwell. It doesn't work first time to me.
#398887
Did it ask if you wanted to add or override (or cancel) the existing license file?
In most cases, the problem is Maxwell 4 is reading first the demo of Maxwell 5 so it sticks with a non-valid license file. We'll try to improve this.
why not have a simple sub-folder for every version.... ?! e.g.
c:\program data......\maxwell\licenses\version 4 etc.
This is a good idea too. Thank you!
Fernando
#398913
Choo-Chee/Fernando,
I had similar experiences with the V5 demo (see post in Rhino sub-section), and lost all MR capability as a result. Fortunately, I could recover from a system backup. As it stands right now, I simply couldn't consider installing the demo again, or upgrading until this is addressed, which sounds like it would be a relatively easy thing to fix?
Is it possible for MR 3/4 to coexist alongside MR5? I have a stable configuration of Rhino5 and MR3 running, and would hate to lose that capability...
