By Q2
#398479
Yupp, I tried them out a couple of years back. Worked fine then.
Haven't used them since cause I usually use Ranch Computing now, since I know from experience that they have an excellent customer service.
Cheers from Bavaria
Q!
By mjcherry
#398521
I'm not connected to FastRender at all, but I have used them (and others) in the past and I have found them the absolute best for rendering Maxwell files. When you submit the render, an actual person checks the file and gets the render going. They have always been reasonably priced and the results are always perfect.
