Everything related to the integration for 3dsmax.
By James Linehan
#398167
I can have objects with standard textures in 3ds Max export them using the Maxwell seen file. Then I can import them into Maxwell studio save them. When I opened them up in 3ds DS Max all the textures are now sign the appropriate Maxwell shader so I can adjust the materials properties with standard Maxwell shader. is there any way to translate the textures without going through this process? I can translate vray by just one click of a button
thanks
#398226
Hello James,
You can export the objects to an mxs file and then import them right away from 3dsmax 's File menu > Import.
You don't have to go through Studio at all.
Best,
Fernando
