By Q2
#398148
Hi Guys, I have a script that changes my Emitter value in an Animation sequence from Zero to 500 watts.
It used to run fine, but now I get this error message:
Uncaught exception at <anonymous script, id=1437229225744>:1: SyntaxError: Parse error
Any idea what is going on?
Here's the script:
#============== CHANGE THESE VARIABLES AS REQUIRED ==============
mxs_dir = 'C:\Users\Carsten Quilitz\Desktop'
mat_name = 'Emitter'
watts_min = 0
watts_max = 500
#================= DON'T CHANGE ANYTHING ELSE =================
import os
import sys
from pymaxwell import *
mxs_dir = os.path.normpath(mxs_dir)
if not os.path.isdir(mxs_dir):
print('ERROR: input dir not found: %s' % mxs_dir)
sys.exit(1)
mxs_files = getFilesFromPath(mxs_dir, '.mxs')
if not len(mxs_files):
print('ERROR: no MXS files found: %s' % mxs_dir)
sys.exit(1)
mxs_files.sort()
incr = (watts_max - watts_min) / float(len(mxs_files))
watts = watts_min
def read_emitter(mxs_path):
mw = Cmaxwell(mwcallback)
if not mw.readMXS(mxs_path):
print('ERROR: Failed to read %s.' % mxs_path)
mw.freeScene()
return None,None,None
material = mw.getMaterial(mat_name)
if material.isNull():
print('ERROR: Failed to find "emitter" material in %s.' % mxs_path)
mw.freeScene()
layer = material.getLayer(0)
if layer.isNull():
print('ERROR: Failed to find layer 0 for "emitter" material in %s.' % mxs_path)
mw.freeScene()
emitter = layer.getEmitter()
if emitter.isNull():
print('ERROR: Failed to find emitter for layer 0 in %s.' % mxs_path)
mw.freeScene()
pair,ok = emitter.getPair()
if not ok or emitter.isNull():
print('ERROR: Failed to get emitter pair for layer 0 in %s.' % mxs_path)
mw.freeScene()
return mw,emitter,pair
for mxs_file in mxs_files:
mxs_path = os.path.join(mxs_dir, mxs_file)
mw,emitter,pair = read_emitter(mxs_path)
if not mw:
continue
pair.watts = watts
emitter.setPair(pair)
if not mw.writeMXS(mxs_path):
print('ERROR: failed to write %s' % mxs_path)
else:
print('OK: adjusted emitter to %s in %s.' % (watts, mxs_path))
mw.freeScene()
watts = watts + incr
THANKS!
CHEERS FROM BAVARIA
Q!
By Q2
#398156
Ok, I found that the line:
needs to be:
from pymaxwell4 import *
and the script does finally start running.
EXEPT! now it stops at:
NameError: name 'mxs_dir' is not defined
Any ideas what I have to change to get it working?
CHEERS Q!
Installed the latest MW V5 for Rhino 6 (Windows)..[…]
Attic
Hi, https://www.janwalter.org/assets/attic_maxwe[…]
HDRI
Hello Mike, I'm not sure what you are doing with […]
Texture/finish lost in render.
Hello Mike, I'm sorry for the late reply. I coul[…]
