- Tue Feb 26, 2019 12:08 am
#398050
I'm trying to use the vray to Maxwell script on these assets from megascan https://quixel.com/. They import as v-ray materials but the script errors when trying to convert them here's the error
-- MAXScript Rollout Handler Exception:
-- Unable to convert: undefined to type: String
-- MAXScript callstack:
-- thread data: threadID:24520
-- [stack level: 0]
-- In VrayHDRI2hdr(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 12336; line: 248
-- member of: StructDef:mtlconverter
-- Parameters:
-- MapOrig: VRayHDRI:VRayHDRI
-- g: 1
-- Locals:
-- m: Maxwell_Bitmap:MaxwellBitmap
-- nom: "D:\library\Downloaded\surface\rock_cliffs_sjggaija\sjggaija_4K_Gloss.jpg"
-- g: 1
-- nomproc: undefined
-- Externals:
-- owner: (mtlconverter mwvars:(mwvars owner:undefined widthproc:512 procext:".jpg" convertedmats:#() oldcams:#() newcams:#() oldLights:#() newlights:#() validmaptype:#(".jpg", ".png", ".tga", ".tif", ".tiff", ".hdr", ".exr", ".bmp") sourceMtlClasses:#("VRayMtl", "VRayLightMtl", "VRayBlendMtl", "VRay2SidedMtl", "VRayMtlWrapper", "VRayOverrideMtl", "Blend") sourceLightClasses:#("VRayLight", "VRayIES", "VRaySun", "freeSpot", "targetSpot") dirproc:"C:\Users\James\Documents\3dsMax\sceneassets\images\" mw_ibl_on:undefined env_gi_on:undefined env_gi_map:"" env_gi_map_on:undefined env_refl_on:undefined env_refl_map:"" env_refl_map_on:undefined env_refr_on:undefined env_refr_map:"" env_refr_map_on:undefined env_bgrmap:undefined env_sun:false env_dome:false dayname:undefined maxbarvalue:1 currbarvalue:0 msglog:StringStream:"" version:"v1.2") mwconvroll:Rollout:mwconvroll)
-- [stack level: 1]
-- called from convert_map(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 13040; line: 271
-- Parameters:
-- smap: VRayHDRI:VRayHDRI
-- Locals:
-- col: undefined
-- btemp: undefined
-- wsize: undefined
-- clmap: VRayHDRI
-- hsize: undefined
-- Externals:
-- mwconv: Global:mwconv : (mtlconverter mwvars:(mwvars owner:undefined widthproc:512 procext:".jpg" convertedmats:#() oldcams:#() newcams:#() oldLights:#() newlights:#() validmaptype:#(".jpg", ".png", ".tga", ".tif", ".tiff", ".hdr", ".exr", ".bmp") sourceMtlClasses:#("VRayMtl", "VRayLightMtl", "VRayBlendMtl", "VRay2SidedMtl", "VRayMtlWrapper", "VRayOverrideMtl", "Blend") sourceLightClasses:#("VRayLight", "VRayIES", "VRaySun", "freeSpot", "targetSpot") dirproc:"C:\Users\James\Documents\3dsMax\sceneassets\images\" mw_ibl_on:undefined env_gi_on:undefined env_gi_map:"" env_gi_map_on:undefined env_refl_on:undefined env_refl_map:"" env_refl_map_on:undefined env_refr_on:undefined env_refr_map:"" env_refr_map_on:undefined env_bgrmap:undefined env_sun:false env_dome:false dayname:undefined maxbarvalue:1 currbarvalue:0 msglog:StringStream:"" version:"v1.2") mwconvroll:Rollout:mwconvroll)
-- owner: <CodeBlock:anonymous>
-- [stack level: 2]
-- called from vray2mw(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 27094; line: 545
-- Parameters:
-- origMtl: rock_cliffs_sjggaija:VRayMtl
-- Locals:
-- m: rock_cliffs_sjggaija:MaxwellMaterial
-- cls: undefined
-- mtln: 0.0
-- tex: undefined
-- rfr: (color 51 51 51)
-- Externals:
-- mwvars: Struct member:mwvars : (mwvars owner:undefined widthproc:512 procext:".jpg" convertedmats:#() oldcams:#() newcams:#() oldLights:#() newlights:#() validmaptype:#(".jpg", ".png", ".tga", ".tif", ".tiff", ".hdr", ".exr", ".bmp") sourceMtlClasses:#("VRayMtl", "VRayLightMtl", "VRayBlendMtl", "VRay2SidedMtl", "VRayMtlWrapper", "VRayOverrideMtl", "Blend") sourceLightClasses:#("VRayLight", "VRayIES", "VRaySun", "freeSpot", "targetSpot") dirproc:"C:\Users\James\Documents\3dsMax\sceneassets\images\" mw_ibl_on:undefined env_gi_on:undefined env_gi_map:"" env_gi_map_on:undefined env_refl_on:undefined env_refl_map:"" env_refl_map_on:undefined env_refr_on:undefined env_refr_map:"" env_refr_map_on:undefined env_bgrmap:undefined env_sun:false env_dome:false dayname:undefined maxbarvalue:1 currbarvalue:0 msglog:StringStream:"" version:"v1.2")
-- mwconvroll: Struct member:mwconvroll : Rollout:mwconvroll
-- mtlconverter: StructDef:mtlconverter
-- [stack level: 3]
-- called from convertMat(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 40791; line: 934
-- Parameters:
-- Locals:
-- type: VRayMtl
-- Externals:
-- convertMat: Struct member:convertMat : convertMat()
-- [stack level: 4]
-- called from m loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 44744; line: 1036
-- member of: anonymous codeblock
-- Parameters:
-- m: rock_cliffs_sjggaija:VRayMtl
-- Locals:
-- Externals:
-- [stack level: 5]
-- called from i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 44744; line: 1036
-- Parameters:
-- i: "VRayMtl"
-- Locals:
-- scenemats: #(rock_cliffs_sjggaija:VRayMtl)
-- i: "VRayMtl"
-- num: 1
-- Externals:
-- [stack level: 6]
-- called from ConvertScene(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 44753; line: 1037
-- Locals:
-- numbar: 1
-- day_array: undefined
-- barmats: #(rock_cliffs_sjggaija:VRayMtl)
-- r: undefined
-- sceneproxys: #()
-- Externals:
-- [stack level: 7]
-- called from bot_convert.pressed(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\maxwell\mwconverter.ms; position: 7987; line: 116
-- member of: Rollout:mwconvroll
-- Locals:
-- Externals:
-- drop_extension: RolloutControl:drop_extension in rollout:mwconvroll : ComboBoxControl:drop_extension
-- spin_widthproc: RolloutControl:spin_widthproc in rollout:mwconvroll : SpinnerControl:spin_widthproc
-- dlbl_info: RolloutControl:dlbl_info in rollout:mwconvroll : dotNetControl:dlbl_info:System.Windows.Forms.Label
-- chk_selonly: RolloutControl:chk_selonly in rollout:mwconvroll : CheckBoxControl:chk_selonly
-- pbar: RolloutControl:pbar in rollout:mwconvroll : ProgressBar:pbar
-- mwconvroll: Rollout:mwconvroll
-- lbl_pbar: RolloutControl:lbl_pbar in rollout:mwconvroll : LabelControl:lbl_pbar
-- [stack level: 8]
-- called from top-level
-- [stack level: 0]
-- Parameters:
-- g: 1
-- Locals:
-- g: 1
-- Externals:
-- [stack level: 1]
-- Parameters:
-- Locals:
-- col: undefined
-- btemp: undefined
-- wsize: undefined
-- clmap: VRayHDRI
-- hsize: undefined
-- Externals:
-- [stack level: 2]
-- Parameters:
-- Locals:
-- cls: undefined
-- mtln: 0.0
-- tex: undefined
-- Externals:
-- [stack level: 3]
-- Parameters:
-- Locals:
-- type: VRayMtl
-- Externals:
-- [stack level: 4]
-- Parameters:
-- Locals:
-- Externals:
-- [stack level: 5]
-- Parameters:
-- i: "VRayMtl"
-- Locals:
-- i: "VRayMtl"
-- num: 1
-- Externals:
-- [stack level: 6]
-- Locals:
-- numbar: 1
-- r: undefined
-- sceneproxys: #()
-- Externals:
-- [stack level: 7]
-- Locals:
-- Externals:
-- [stack level: 8]
________________________________________________________
Beta testing Maxwell Render since 2006
- By Mark Bell
