Everything related to Studio.
By pipcleo
#397906
Is it possible to create a glazed material like the attached within maxwell ?
Any tips ?
After a (relatively) simple solution that is material based
By LadleSky10
#397907
Not really sure what your question is here but Maxwell Zone has a very nice "glazed material" that comes with its "Fish Vases" model. I'd use that as a starting point and then add an edge wear map and go from there.
By Nasok
#397908
Sure it is.
one layer for the base colour.
second layer for base spec (slightly less rough - good place for roughness map)
and a top layer for a coating.
+ global bump :)
and yep - curvature map for edge wear :) easy to get from apps like Substance Painter, Mari, or, pretty much, any DCC.
Cheers
Sketchup 2019.2
Same issue here, immediate bugsplat on export of a[…]
Moving license to a new computer?
I have the same problem. I've never had trouble ac[…]
Diamond DA42
That fuselage looks nicely resolved, well done to […]
Plugin Request Thread
What with the huge increase in AI, making our dear[…]
