By giacob
#42308
since nobody answer i presume the question was too much stupid ....then i presume i will get a 4h render for each pc...
another question ... is is possibile seeing the render in the consolle while processing and adjust parameters like in normal render?
By animated
#42342
no .. you will have to wait 8 hours with both machines and the resul is not a 16 hour render, is something like a mix of the two images, but yes, the final image is better than using only one machine, but dont expect the same result as a 16 hour render. :wink:
By ludi
#42407
Not everytime,
If you render a animation, each machine can render a frame in a single process, so you can divide the time by the numbers of machines....ok not absolute (network & preparation like reading mxs & voxelisation will delay) but that´s a general habit of networkrendering.
