- Thu Nov 08, 2018 5:51 pm
#397826
1. After using Fire and then switch to production it is cause crushing 3d max every time
2. Fire render over all running super slow, problem with light when you move it.
Because of that Fire is absolutely pointless to have.......
3. When you using two layers material and trying to change color it is cause to processing something???? and you need to wait every time you want to change RGB color.
4. When you change texture it is not updating automatically and you need to do it manually.
5. Denoiser still have sometimes problems with interiors scene with a lot of lights at high resolutions.
6. Denoiser do incorrect light behind glass.
- By Matteo Villa
