- Sun Aug 05, 2018 1:29 pm
#397447
Hi guys!
I'm having some troubles using ies files.
I've created a ground spot and i've putted a plane with 2 cm inside where I've applied the emitter material with a ies file.
Turns out that it renders a sphere always. Even if I use a maxwell tag to make it invisible to the camera.
Any clue if this is possible?
Thanks in advance,
Bruno
Thanks in advance,
Bruno
