- Sat Jun 09, 2018 12:46 pm
#397225
Hello, it has been many times i've encounter this and finally i've decided to post it.
I dont understand what is going on but randomly Maxwell render does not finsh the render i let run over night.
Sadly there is nothing on the logs and this behaviour is very strange. First off i run the render with denoiser set to each SL, rendering is done in CPU mode, the denoising is set to use GPU and Accurate so it creates the extra channels.
Target SL is 25, time is 14400, pretty standard out of the box settings. One thing i've changed was setting the cpu priority to "Normal" instead of low. I am going to try o leave it to low.
When i launch the rendering everything works fine only to find the morning after that the rendering is still going at SL 4 ( after 9 hours) and the CPU usage is at 0.
The countdown on top of the maxwell rendering still runs with extimate time left, but the render is not progressing, on the task manager its not using any cpu, basically its like stopped.
This happened more than 5 times and its a lot of frustration. Anyone had this behaviour at all? As i said there is nothing in the logs because its like the rendering is still going on but it is not.
Im running the latest Maxwell Render version.
