By dvsone1440
#396427
When rendering my site jpgs are misaligned.. and each time I render they seem to move? See attached skp image and rendering.
#396430
Well, let's see; textures are positioned on your geometry using UV coordinates, so for them to move, the UVs have to change.
So, it could be that you have set the group/component containing the geometry to use a camera projection by enabling context menu > Maxwell > UV Coordinates > Camera. It could also be you are using one of the other custom UV projections in that list, and that the group/component has had geometry added/removed/moved (the UVs being calculated based on bounding box, they will change, if the bounding box changes) between exports. Depending, it could also involve context menu > Maxwell > UV Coordinates > Ignore Distortion.
Possibilities outside those would involve SketchUp providing wrong/different UV coordinates for some reason that I couldn't guess, whether due to some issue with the geometry itself (geolocation, as seems potentially in use here, has been known in the past to supply corrupt images, though that doesn't seem to fit the description in this case), some other plugin coming into play, and so forth.
Another interesting factor would have to with whether you are saying this is something that is consistently happening in different models, or if it appears to be related to this specific model.
By dvsone1440
#396431
Definitely this specific model. Do this all the time without this problem although I have a vague recollection of it happening once a long time ago, but of course I don’t remember the resolution. I will look into the things you mention and see what I find. The strangest thing is that every time I re-render (different machine and or view) it seems to move differently.
By dvsone1440
#396433
Interesting.. I copy pasted the topo into a new model and it worked as expected. Must be something corrupt in that skp model.
By dvsone1440
#396435
So that worked in a test (copy paste) but when I did the whole thing it did not.
Then I noticed the texture had a weird dimension 2871'-3/14" x 1515' - 2" I resized it to 2871' x 1515' and it now works as expected.
