By Q2
#396351
Hi guys, I need to create something like this:
https://www.turbosquid.com/3d-models/3d ... ng/1083074
Since I am using Rhino to animate my scene and render everything via the Maxwell plugin, does anyone have an idea on how to generate these kind of flames?
Cheers Q!
#396362
Might be overkill for your situation, that animated burner used length-scale and rotation, but you need to play with the timing to get a smooth effect, I am looking for simpler technique reference posted rusteberg;
I also found this render though, no idea where it comes from;
Also found this mb test which uses per frame timing of the spline radius scale to make a 'light trail'
By Q2
#396363
NICE!!!!!!!
Thanks so much, I am also working on something similar.
I also want to have the flames move along a straight line of burner holes and change size while doing so just like in the animation on the turbo squid link above....
Tricky though. I keep you posted.
Cheers Q!
