#395946
I tried to install the Maxwell for Rhino plugin V4 on a new machine and when I tried to select Maxwell as the Renderer from the dropdown it wasn't listed. BTW, the Maxwell for Rhino install reported that it had installed successfully.
I also tried dragging the MaxwellRhino.rhp file into plugins folder and get the following error message that it couldn't load the file or assembly.
Any help greatly appreciated.
Thnx.
jvm
