- Thu Oct 12, 2017 11:05 am
#395717
Hello
i run the script of maxwell tool in MAC on virtual system
like in windows i rename pymaxwell4.py to __ini__.py than i replace MAXWELL 3 by MAXWELL 4
the problem now in this line :
but i got another error :
Code: Select all
when i run the script and try to render a scene i got this error :
elif sys.platform == 'darwin':
parameters.insert(0,'/Applications/Maxwell 3/Maxwell.app/Contents/MacOs/Maxwell');Code: Select all
i tried to rename the location to : parameters.insert(0,'/Applications/Maxwell Render 4');
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/pymaxwell/__init__.py", line 135, in runMaxwell
subprocess.call(parameters);
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/subprocess.py", line 247, in call
with Popen(*popenargs, **kwargs) as p:
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/subprocess.py", line 676, in __init__
restore_signals, start_new_session)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/subprocess.py", line 1289, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: '/Applications/Maxwell 3/Maxwell.app/Contents/MacOs/Maxwell'but i got another error :
Code: Select all
PermissionError: [Errno 13] Permission denied
- By Matteo Villa
