By luis.hijarrubia
#395133
I recommend to change to PyMaxwell, witch also es better documented (for example, pressing F1 on Cmaxwell word will open a window with all functions and there it is a getCamerasCount method), but mainly because the "javascript" intepreter on maxwell.exe is provided by QT and it's deprecated, so on next QT version will disappear and it will disappear from maxwell too.
By seghier
#395138
luis.hijarrubia wrote:
Mon Aug 21, 2017 10:52 am
in pymaxwell : getCamerasCount() but no clear explanation how to use it
Help on method Cmaxwell_getCamerasCount in module _pymaxwell4:
Cmaxwell_getCamerasCount(...) unbound pymaxwell.Cmaxwell method
Method: getCamerasCount() -> (int,ok)
Description: Returns the number of cameras in the scene
Well, a course in Python is beyond the scope of the pymaxwell docs. I guess you would assign the value it returns to a variable. Something like:
yourscene = Cmaxwell(mwcallback);
yourscene.readMXS('myscene.mxs');
nrofcams = yourscene.getCamerasCount();
(I have next to no knowledge on python, so please no further questions 8) )
By seghier
#395140
thanks Mihai
i create this but always an error ( question not for you :D )
from pymaxwell import *
scene.readMXS('c:/input/t.mxs');
nrofcams = 'c:/input/t.mxs'.getCamerasCount();
Traceback (most recent call last):
File "<string>", line 8, in <module>
AttributeError: 'str' object has no attribute 'getCamerasCount'
You would use scene.getCameraCount() I think, not the name of the scene file again. "scene" effectively becomes whatever you've already specified with the scene.readMXS method. From then on, you use all the methods available to the "scene" object, it is implied that this object refers to "t.mxs".
By seghier
#395143
this is the script , thanks for help:
scene.readMXS('mxs location');
print scene.getCamerasCount()
or
value = scene.getCamerasCount();
print value
the result : (3, True) { 3 : cameras number } ; how i can choose the number only ?
can script in maxwell render use script from pymaxwell ?
By seghier
#395144
the script {run_maxwell_render.py} always give error :
MAXWELL3_ROOT environment variable not found!
File "<string>", line 29, in <module>
File "<string>", line 23, in run_maxwell_render
File "C:\Program Files\Next Limit\Maxwell Render 4\python\python\lib\site-packages\pymaxwell\__init__.py", line 127, in runMaxwell
parameters.insert(0,mwroot+'/maxwell.exe');
UnboundLocalError: local variable 'mwroot' referenced before assignment
By seghier
#395156
thanks Luis
the question about the code ?
//code to get the camera you want
i create code to count cameras number and separate them by name or number
and i want know how i can render each camera view ; this is simple in maxwell render script
Code: Select all
scene.readMXS('c:/input/maison.mxs')
### cameras number ###
n,ok = scene.getCamerasCount()
print (n);
### cameras name  ####
list = scene.getCameraNames()
print (list)
for o in (list):
    print (o)
### cameras ID  #######
r = range(n)
print (r)
for o in reversed(r):
    print(o)
