- Fri Mar 03, 2017 1:16 am
#394238
If you try to use a 3D procedural texture as an emitter by applying it via HDR image then Maxwell ignores the concept of 3D world coordinates and only applies the emitter as a 2D image using UV texture coordinates.
This has been the case for a while now, and if it's expected behavior I'd suggest it shouldn't be. I would like to be able to use 3D World coordinate textures as emitters.
previously:
http://www.maxwellrender.com/forum/view ... 1&p=394237
previously:
