By seghier
#393381
Hello
i see a holographic material created by vray and it's very nice and very realistic
i searched here and i find old threads asked for the same material without solutions
i tried with this one but i need it more realistic
the problem that the color changed hanged with the change of angle
test :
https://www.youtube.com/watch?v=0PgoD3Rlk60
By Nasok
#394298
Nice one :)
Would love to have it also :)
In reality that is what it is - the colour spectrum is changed based on a viewing angle :)
That way you can see something from once side and not from another.
Altho, I think that for making it a truly holographic you should shift the texture map inside a bit depending on an angle that way you will have that visible "depth"
Beside that - coating is a little helper here :)
P.S. and couple version of the same texture with different parameters :)
