Everything related to SDK.
By znouza
#41645
- STOP TIME property - time is in SECONDS, not minutes as described
- in pseudo code - there's no newScene() method, the same for createCamera .. you have to createCameras(), then setCamera()
- in setCamera() - focal length is in mm, not in meters
- in createCameras() - shutterspeed is in seconds
- when I don't set output image, and call writeMXS(), rhino crashes
Crgb::assign() expects RGB values as float (color/255)
By albertMaxwell
#42642
Yes znouza it's correct.
But, all parameters are in seconds and metters.
It includes setCamera, focal length is in METERS
Thank you
By znouza
#42649
albertMaxwell wrote:Yes znouza it's correct.
Thank you
then something is wrong. if I set focal length in meters (rhino returns it in mm), I'll get black render with some bright dots in the center of image. so, if I leave focal length untouched (in mm), all is OK
so where's the problem. does SDK some method to specify scene scale? I mean it doesn't
