By andronikos916
#41621
1) first of all those two scenes are completly different
2) CPU power is different
... :lol:
Andron
By andronikos916
#41631
maxxoros wrote:I understand the scene is DIFFERENT but I want to compare the complicated of each scene
First scene have a lot of polygon and more object, more corner
My scene is quite simple
But is TOO LONG to finish
The CPU is different, they may be using a dual xeon or more...but...as I know by testing with my friend, the render speed only increase 150 % max
quite do not understand a simple like this take me about 2.5 h to finish :?
...for better understanding visit the following links and if you link give it a try.
http://www.maxwellrender.com/forum/view ... mark+scene
Not only the polygon count matters for speed and noise but also materials and color.
cy,
Andronikos
In your case most of the light is indirect (you have an interior scene), their scene is exterior (most light is direct light). Interiors will take a lot more to render. Also, don't put your white wall material too high, If you set it to 245-255 it will take even longer to get rid of the noise.
By VisualImpact
#41654
sample is 25, physic sky, low quality
you mention low quality, what version are you using
By jomaga
#41677
I´ve tested a similar scene with diffuse materials & 3 500W emitter
This image is made with a Pentium III 1,1 GHz + 512 Mb ram
Reached S. level 8 in 3m 19s
