#392980
Why do you use such a complicated material? I mean you can use object opacity, layer opacity or ghost material (k=0, nd=1, transmitance = pure white). Any of this three options give you invisibility without shadows. I have to check better the material used in your example to see what happen there anyway.
By seghier
#392981
because i want use it for boolean to create some effects like in cheese but the shadows is the problem
i used the material with these settings
transmitance : pure white
attenuation : 999m
nd:1
k:0
roughness:0
and the object throw the shadow
the opacity yes i used it when i need hide objects or part of an object
#392984
seghier wrote:that's good thanks but the shadow of the invisible object become visible if they are aligned to the camera
can you confirmed that ?
I'm playing with the ball, moving it, and moving the camera for 2 mins and I'm not able to throw that shadow. How do you that?
