- Wed Oct 19, 2016 6:48 pm
#392799
As soon as I hit fire GPU in MODO it crashes (Everytime without fail). Fire CPU works fine.
Rendering to GPU works fine too.
Windows 10 Pro 64Bit
Geforce GTX 970 4GB - NVIDIA Drivers : 373.06
MODO 902 SP3
UPDATE:
Adding Geometry to Modo while CPU Fire is running crashes MODO - If I launch Modo and then add a Sphere then click fire CPU everything is fine but as soon as I add a second geometry item while the fire CPU is running MODO crashes.
When running Maxwell.exe I get this pop up but before rendering starts - It proceeds to rendering just fine after the prompt
Monitor Res is 3440 x 1440
MODO 902 SP3
UPDATE:
- By Mark Bell
- By Edward Leibnitz
