By choo-chee
#392720
using quadro 4GB ram, decided to try V4 as demo before using my promo upgrade... it seems no matter what i do, V4 GPU cannot render any typical scene of my daily work. CPU works... but switching to GPU mode, maxwell just hang forever in "start rendering" that started within 30-90 secs. in CPU mode. it will also not close properly like in CPU - must be killed via task manager. very simple with almost nothing inside... it will work, maybe faster - cannot decide with a box and sphere !
#392724
That's a Kepler card. Officially we only support Maxwell and Pascal Cards. But we made a lot of testing with Kepler cards (even some developers here have Kepler to develop in their machines) and although it can be slower than cpu in some cards, it always worked. Can you show console and copy if there's any useful info there?
By choo-chee
#392725
GPU available: Quadro K2200 (OpenCL 1.2)
===================== New session opened at 18/October/2016 11:51:43 =====
MAXWELL RENDER (M~R). Engine version 4.0.0.5
(C) 2004-2015. Licensed to Next Limit Technologies
C:\Program Files\Next Limit\Maxwell For Maya\maxwell.exe
RUNTIME INFO
Root dir: C:\Program Files\Next Limit\Maxwell For Maya
Home dir: C:\Users\Yossi\Documents\Maxwell
LICENSE INFO
WARNING: - Using license path with MAXWELL4_LICENSE_PATH environment variable : C:\ProgramData\Next Limit\Maxwell\licenses.
License found in standard license path : C:\ProgramData/Next Limit/Maxwell/licenses/maxwell_license.lic
Scanning C:\ProgramData\Next Limit\Maxwell\licenses folder for licenses
Processing file C:/ProgramData/Next Limit/Maxwell/licenses/maxwell_license.lic
Processing file C:/ProgramData/Next Limit/Maxwell/licenses/maxwell_studio.lic
Successfully checked out license from file C:/ProgramData/Next Limit/Maxwell/licenses/maxwell_studio.lic
License type: DEMO MODE
License name: Demo Customer
Company: Demo Company
Expiration date: 12-nov-2016
Issued by: nextlimit
License node-locked to host ID: 408d5cbda57d
WARNING: - License Warning Your license will expire in 26 days. Please visit your customer portal to renew. https://portal.nextlimit.com/
SYSTEM INFO
Num processors: ( logical: 12, physical: 12 )
Maxwell Root folder :C:\Program Files\Next Limit\Maxwell For Maya\
This machine Host ID: 408d5cbda57d
Low Priority Enabled
Demo Mode
Found 5 procedural extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
MaxwellHair
MaxwellParticles
MaxwellVolumetric
MGrassH
MGrassP
Found 6 geometry loader extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
AssetReference
MaxwellMesher
MaxwellSea
MWObjectAlembic
RFMeshes
RWMeshes
Found 4 geometry modifier extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
MaxwellCloner
MaxwellGrass
MaxwellScatter
SubdivisionModifier
Found 12 texture extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
Brick
Checker
Circle
Gradient3
Gradient
Grid
Marble
Noise
Voronoi
MultiPointGradient
TiledTexture
WireframeTexture
Found 7 material modifier extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
AGS
Opaque
Transparent
Metal
Translucent
Car Paint
Hair
Found 2 camera lens extensions in C:\Program Files\Next Limit\Maxwell For Maya\extensions-x64-v120
Lat-Long Stereo
Fish Stereo
[18/October/2016 11:51:43] There are no updates available
By seghier
#392728
luis.hijarrubia wrote:That's a Kepler card. Officially we only support Maxwell and Pascal Cards. But we made a lot of testing with Kepler cards (even some developers here have Kepler to develop in their machines) and although it can be slower than cpu in some cards, it always worked. Can you show console and copy if there's any useful info there?
so the card in my laptop is not supported ?
i tried other gpu render engine and they all worked fine
By choo-chee
#392730
here's another one, while trying to render a scene (stuck here for about 5 minuets):
===================== New session opened at 18/October/2016 12:02:20 =====
RUNTIME INFO
LICENSE INFO
SYSTEM INFO
Demo Mode
MaxwellHair
MaxwellParticles
MaxwellVolumetric
MGrassH
MGrassP
AssetReference
MaxwellMesher
MaxwellSea
MWObjectAlembic
RFMeshes
RWMeshes
MaxwellCloner
MaxwellGrass
MaxwellScatter
SubdivisionModifier
Brick
Checker
Circle
Gradient3
Gradient
Grid
Marble
Noise
Voronoi
MultiPointGradient
TiledTexture
WireframeTexture
AGS
Opaque
Transparent
Metal
Translucent
Car Paint
Hair
Lat-Long Stereo
Fish Stereo
[18/October/2016 12:02:27] Reading MXS:D:/farm/aba.mxs
[18/October/2016 12:02:28] MXS file read successfully
WARNING: - Image output path is not valid or has not been set and will be saved in: C:\Users\Yossi\AppData\Local\Temp\aba.png
WARNING: - Default behavior for invalid paths can be changed in Menu/Preferences
WARNING: - MXI output path is not valid or has not been set and will be saved in: C:\Users\Yossi\AppData\Local\Temp\aba.mxi
CPU ID used: 11766
[18/October/2016 12:02:41] Checking scene dependencies..
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/RAL/glossy metallic plastic/roughness_noise.png
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/RAL/glossy plastic/roughness_noise.png
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/_5.jpg
[18/October/2016 12:02:59] File _5.jpg found in folder: D:\farm\sourceimages\_5.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/sourceimages/tris.jpg
[18/October/2016 12:02:59] File tris.jpg found in folder: D:\farm\sourceimages\tris.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/textures/Arroway/concrete-19_s050-g050.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/textures/Arroway/concrete-19_b005.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/textures/Arroway/concrete-19_d100.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/sourceimages/pave8.jpg
[18/October/2016 12:02:59] File pave8.jpg found in folder: D:\farm\sourceimages\pave8.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/25CS_tre.jpg
[18/October/2016 12:02:59] File 25CS_tre.jpg found in folder: D:\farm\sourceimages\25CS_tre.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/sourceimages/Concrete.jpg
[18/October/2016 12:02:59] File Concrete.jpg found in folder: D:\farm\sourceimages\Concrete.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/35HD_dor.jpg
[18/October/2016 12:02:59] File 35HD_dor.jpg found in folder: D:\farm\sourceimages\35HD_dor.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/Erba.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/Erba_B.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/terrain.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/terrainbump.bmp
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/Grass-M1-03.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/misc-yoss/Grass-M1-00-B.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/Metal_Co.jpg
[18/October/2016 12:02:59] File Metal_Co.jpg found in folder: D:\farm\sourceimages\Metal_Co.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/sourceimages/deck22.jpg
[18/October/2016 12:02:59] File deck22.jpg found in folder: D:\farm\sourceimages\deck22.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/Stone_Ma.jpg
[18/October/2016 12:02:59] File Stone_Ma.jpg found in folder: D:\farm\sourceimages\Stone_Ma.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/scenes/_6.jpg
[18/October/2016 12:02:59] File _6.jpg found in folder: D:\farm\sourceimages\_6.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/STREET/sourceimages/pas1.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/STREET/sourceimages/STON50L.JPG
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-19_s050-g050.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-19_b005.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-19_d100.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/tiles-44_s100-g100.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/tiles-44_b015.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-36_s025-g025.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-36_b010.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell 2/materials database/textures/arroway/concrete-36_d100.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/cars/AsPck_02_NORMAL.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/cars/AsPck_02_SPECULAR.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/cars/AsPck_02_DISP.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/cars/AsPck_02_DIFFUSE.jpg
[18/October/2016 12:02:59] Dependency found: C:/Program Files/Next Limit/Maxwell/materials database/mxm files/metalz/2.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/STREET/sourceimages/roadgerets.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/STREET/sourceimages/pas3.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/arroway_v2/tiles-44_s100-g100.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/arroway_v2/tiles-44_b015.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/arroway_v2/tiles-44_d100.jpg
[18/October/2016 12:02:59] Searching in alternative paths: D:/1-works/��� ��� 46-48/maya/sourceimages/fnc-tera.tif
[18/October/2016 12:02:59] File fnc-tera.tif found in folder: D:\farm\sourceimages\fnc-tera.tif
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/tree-plumeria.mxs
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/koraDivlje1b.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/koraDivlje1.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/leaf-back2r.JPG
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/leaf-back3.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/leaf-front2-r.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/leaf-back2.JPG
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/NAT514_B.JPG
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/flower22.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/PLANTs/ibush5a.mxs
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/wood/Bark-d.jpg
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/wood/Bark-n.tga
[18/October/2016 12:02:59] Dependency found: D:/2-library/Maxwell 2/materials database/mxm files/wood/Bark-s.jpg
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/PLANTs/sourceimages/rose_leaf_01_color.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/big-sml-tree.mxs
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/sourceimages/archmodels58_028_bark_diffuse.jpg
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/Archmodels61_juglans_nigra_leaf_diffuse_NRM.jpg
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/Archmodels61_juglans_nigra_leaf_opacity.tif
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/Archmodels61_juglans_nigra_leaf_diffuse.jpg
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/kadur-kaved2.mxs
[18/October/2016 12:02:59] Dependency found: D:/farm/sourceimages/mpm_vol.09_p25_leaf_1_bump.JPG
[18/October/2016 12:02:59] Dependency found: D:/farm/sourceimages/mpm_vol.09_p25_leaf_1_mask.JPG
[18/October/2016 12:02:59] Dependency found: D:/farm/sourceimages/mpm_vol.09_p25_leaf_1_front_diff.JPG
[18/October/2016 12:02:59] Dependency found: S:/MAXWELL_LIBRARY/TREEs/big-mint-5.mxs
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/mpm_vol.09_p25_leaf_1_bump.JPG
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/mpm_vol.09_p25_leaf_1_mask.JPG
[18/October/2016 12:02:59] Dependency found: //Antec3-pc/maxwell_library/TREEs/sourceimages/mpm_vol.09_p25_leaf_1_front_diff.JPG
[18/October/2016 12:03:00] Checking Data
[18/October/2016 12:03:00] Preprocessing scene...
DEBUG: - Cuda render engine enabled.
[18/October/2016 12:03:00] Preprocessing data.
[18/October/2016 12:03:00] Memory used before preprocessing: 1561 Mb
DEBUG: - Preprocessing scene modifiers.
[18/October/2016 12:03:00] Loading geometry extensions.
DEBUG: - Preprocessing MXS references.
[18/October/2016 12:03:00] Loading MXS references...
[18/October/2016 12:03:10] MXS references loaded successfully
DEBUG: - Pretessellating meshes with displacement.
DEBUG: - Checking spot/IES lights.
DEBUG: - Initializing data.
DEBUG: - Preprocessing geometry.
DEBUG: - Preprocessing materials.
WARNING: - Material ( GMplastic_9016_Traffic_White ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( GMplastic_9003_Signal_white ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial63 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( concrete_38 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial57 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial53 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial59 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial61 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial60 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( concrete_19 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( road2wide_tiles_44 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( concrete_36 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( road2_AsPck_02_Asphalt ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( concrete_37 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( tiles_45 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial3 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial5 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial6 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial4 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( Bark1 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( maxwellLayeredMaterial ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( tree_sml:maxwellLayeredMaterial49 ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( Bark ) has additive layers, which are still not supported in the GPU engine.
WARNING: - Material ( Model_model_vol10 ) has subsurface scattering, which is still not supported in the GPU engine.
WARNING: - Material ( Model_model_vol10 ) has thin subsurface scattering, which is still not supported in the GPU engine.
WARNING: - Material ( Model_model_vol9 ) has subsurface scattering, which is still not supported in the GPU engine.
WARNING: - Material ( Model_model_vol9 ) has thin subsurface scattering, which is still not supported in the GPU engine.
WARNING: - Material ( Bark2 ) has additive layers, which are still not supported in the GPU engine.
DEBUG: - Preprocessing additional parameters.
[18/October/2016 12:03:18] Memory used after preprocessing: 2926 Mb
DEBUG: - Initializing render engine.
DEBUG: - Demo edition enabled.
DEBUG: - Interactive mode enabled.
WARNING: - Reflection/Refraction passes are still not supported in the GPU engine and will be disabled for rendering.
DEBUG: - Initializing multilight data.
[18/October/2016 12:03:18] Starting voxelization.
Scene Info:
Image output: D:\1-works\��� ��� 46-48\maya\images\camera2\total3.png
MXI output: D:\1-works\��� ��� 46-48\maya\images\camera2\total3.mxi
Geometry:
- Num Objects: 14984
- Num Meshes: 14934
- Num Triangles: 5806571
- Num Vertexes: 4894702
- Num Normals: 4804384
- Num Materials: 71
Camera: camera2
Render settings:
- Engine version : 4.0.0.5
- Using RSC engine
- Desired rendering time : 14400
- Desired sampling level : 50.000000
- Using 12 threads
- Multilight type: Disabled
- Save lights in separate files:No
- Motion blur: disabled
- Displacement: enabled
- Dispersion: disabled
- Illumination layers:
. . direct layer: true
. . indirect layer: true
. . direct caustic reflection layer: true
. . direct caustic refraction layer: true
. . indirect caustic reflection layer: true
. . indirect caustic refraction layer: true
[18/October/2016 12:03:18] Start Voxelization
[18/October/2016 12:04:15] End Voxelization
[18/October/2016 12:04:15] Voxelization done.
[18/October/2016 12:04:15] Memory used after voxelization: 3630 Mb
By Herbo
#392738
I have been having the exact same problems... sometimes the renders simply wont start. Right now i have one "cooking" that has been saying "start rendering" for the past 42 minutes :-)... i'm on a Titan x (maxwell)... it started after 3 minutes in cpu-mode. both have been started from the sketchup plugin in the stand alone render.
By Max
#392745
GPU doesnt support several things, you are using them most likely.
Your materials look like they all have additive layers, which is not supported. SSS is not supported, read the warnings :)
Nextlimit should put a sticked thread on the forum with everything that is not supported. As far as i can remember this isnt supported:
1) Only CUDA cards are supported, if you have an OPENCL card it doesnt work (amd)
2) Additive Layers material are not supported
3) Subsurface scattering is not supportede
4) Thins Subsurface is not supported
5) Reflection/Refraction Passes are not supported
6) Grass is not supported
might be something else but i dont remember.
#392746
Unsupported things should not break a render. We are looking into huge scenes. For the moment it crashes or renders in a decent time in my PC, but we are looking into specific circumstances that make make the memory do strange things and takes so long.
