- Wed Aug 17, 2016 4:10 am
#391944
Hey All,
Setup
Renderfarm Manager - Thinkbox Deadline v7.1
Windows 10 Systems
Maxwell v3.2.1.4
Mac OS X 10.11.3
Maxwell v3.2.1.3
Error details
Command
Also, if we go back to a Mac OS X System to resume, the MXI is corrupted.
Example Render Task Process
Task Log from Slave (Windows 10 system)
Setup
Windows 10 Systems
Maxwell v3.2.1.4
Mac OS X 10.11.3
Maxwell v3.2.1.3
Error details
Command
Code: Select all
We're experiencing an somewhat odd error when resuming our renders. If the renders start on a Windows system and resume on a Windows system, they are OK. If they resume on a Mac OS X system they render OK. If they then go to back to a Windows system to resume we get the following error at the end:C:\Program Files\Next Limit\Maxwell 3\maxwell.exe -mxs:N:\renderfarm\Koala_Hospital\Render\Right_Camera\Right_Cam.0000.mxs -nowait -hide -animation:660-660 -threads:0 -time:45 -sampling:16.0 -node -verbose:4 -output:N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.exr -mxi:N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.mxi -trytoresumeTo me this indicates that Maxwell isn't paying attention to the command parameters and outputting the file to the OS X used location.2016-08-17 10:33:39: 0: STDOUT: can't open /Volumes/Network/renderfarm/Koala_Hospital/Render/Rendered_Frames/Right_Cam/Right_Cam.0660.exr for writing.
- Windows - start render - OK
- Windows - resume render - OK
- Mac OS X - resume render - OK
- Windows - resume render - Write fail for image
- Mac OS X - resume render - MXI "/Volumes/Network/renderfarm/Koala_Hospital/Render/Rendered_Frames/Right_Cam/Right_Cam.0044.mxi" is an invalid/obsolete MXI to resume. Unable to resume file.
Code: Select all
Log
2016-08-17 09:48:26: BEGIN - WCI00210238DT02\deadlineservice
2016-08-17 09:48:26: 0: Start Job timeout is disabled.
2016-08-17 09:48:26: 0: Task timeout is disabled.
2016-08-17 09:48:26: 0: Loaded job: Koala Hospital Right Cam (57ab291ae9f5b542d09ebaee)
2016-08-17 09:48:26: 0: Successfully mapped Z: to \\csumain\studentdata\cci\
2016-08-17 09:48:26: 0: Successfully mapped N: to \\w-b74-scci-nas-1\Network\
2016-08-17 09:48:26: 0: INFO: Executing plugin script c:\Temp\wci00210238dt02\plugins\57ab291ae9f5b542d09ebaee\Maxwell.py
2016-08-17 09:48:26: 0: INFO: About: Maxwell Plugin for Deadline
2016-08-17 09:48:26: 0: INFO: The job's environment will be merged with the current environment before rendering
2016-08-17 09:48:26: 0: Plugin rendering frame(s): 660
2016-08-17 09:48:27: 0: INFO: Stdout Redirection Enabled: True
2016-08-17 09:48:27: 0: INFO: Stdout Handling Enabled: True
2016-08-17 09:48:27: 0: INFO: Popup Handling Enabled: False
2016-08-17 09:48:27: 0: INFO: Using Process Tree: True
2016-08-17 09:48:27: 0: INFO: Hiding DOS Window: False
2016-08-17 09:48:27: 0: INFO: Creating New Console: True
2016-08-17 09:48:27: 0: INFO: Running as user: deadlineservice
2016-08-17 09:48:27: 0: INFO: Executable: "C:\Program Files\Next Limit\Maxwell 3\maxwell.exe"
2016-08-17 09:48:27: 0: INFO: Saving output for this job to N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.exr
2016-08-17 09:48:27: 0: INFO: Saving MXI for this job to N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.mxi
2016-08-17 09:48:27: 0: INFO: Argument: -mxs:"N:\renderfarm\Koala_Hospital\Render\Right_Camera\Right_Cam.0000.mxs" -nowait -hide -animation:660-660 -threads:0 -time:45 -sampling:16.0 -node -verbose:4 -output:"N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.exr" -mxi:"N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.mxi" -trytoresume
2016-08-17 09:48:27: 0: INFO: Startup Directory: "C:\Program Files\Next Limit\Maxwell 3"
2016-08-17 09:48:27: 0: INFO: Process Priority: BelowNormal
2016-08-17 09:48:27: 0: INFO: Process Affinity: default
2016-08-17 09:48:27: 0: INFO: Process is now running
2016-08-17 09:48:29: 0: STDOUT: Installing error mode handler
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Installing error mode handler
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: MAXWELL RENDER (M~R). Engine version 3.2.1.4
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: (C) 2004-2015. Licensed to Next Limit Technologies
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: C:\Program Files\Next Limit\Maxwell 3\maxwell.exe -mxs:N:\renderfarm\Koala_Hospital\Render\Right_Camera\Right_Cam.0000.mxs -nowait -hide -animation:660-660 -threads:0 -time:45 -sampling:16.0 -node -verbose:4 -output:N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.exr -mxi:N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.mxi -trytoresume
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: LICENSE INFO
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Found environment variable "nextlimit_LICENSE=5056@XX"
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: License type: FACULTY LICENSE
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: License name: XX
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Company: XX
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Expiration date: 20-oct-2016
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Issued by: NEXTLIMIT
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: License checked out from server ID: XX
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: SYSTEM INFO
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Num processors: ( logical: 8, physical: 8 )
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Maxwell Root folder :C:\Program Files\Next Limit\Maxwell 3\
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: This machine Host ID: 001e0b3625be
2016-08-17 09:48:29: 0: STDOUT: maxwell:[INFO]: Low Priority Enabled
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 5 procedural extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellHair
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellParticles
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellVolumetric
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MGrassH
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MGrassP
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 6 geometry loader extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: AssetReference
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellMesher
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellSea
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MWObjectAlembic
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: RFMeshes
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: RWMeshes
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 4 geometry modifier extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellCloner
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellGrass
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MaxwellScatter
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: SubdivisionModifier
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 12 texture extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Brick
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Checker
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Circle
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Gradient3
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Grid
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Marble
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Noise
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Voronoi
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: MultiPointGradient
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: TiledTexture
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: WireframeTexture
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 7 material modifier extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: AGS
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Opaque
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Transparent
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Metal
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Translucent
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Car Paint
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Hair
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Found 2 camera lens extensions in C:\Program Files\Next Limit\Maxwell 3\extensions
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Lat-Long Stereo
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: Fish Stereo
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Reading MXS:N:\renderfarm\Koala_Hospital\Render\Right_Camera\Right_Cam.0660.mxs
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: MXS file read successfully
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: CPU ID set randomly: 1368
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Flag "Resume render if MXI exists" enabled
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Rendering animation. Loading frame:660.
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: CPU ID set randomly: 8662
2016-08-17 09:48:30: 0: STDOUT: maxwell:[INFO]: CPU ID used: 8662
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Checking scene dependencies..
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Searching in alternative paths: D:/Daniel Abend/CCI300/Assessment_1/Koala_Hospital/sourceimages/T_Koala_D.jpg
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: File T_Koala_D.jpg found in folder: N:\renderfarm\Koala_Hospital\Render\Right_Camera\T_Koala_D.jpg
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Searching in alternative paths: ¿.7z
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [WARNING]: File not found in alternative paths: ¿.7z
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Checking Data
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Loading Bitmaps & Preprocessing Data
2016-08-17 09:48:30: 0: STDOUT: maxwell:[17/August/2016 09:48:30] [INFO]: Loading geometry extensions.
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MaxwellGrass] Executing Mesh Modifier Extension :"Australia2"
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MaxwellGrass] Modifying mesh..
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MaxwellGrass] Generating blades..
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MaxwellGrass] Exporting blades..
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MaxwellGrass] Generating 6100 blades
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MGrassP] Initializing Extension Object
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MGrassP] GrassP : no motion blur info!
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MGrassP] Root Radius=0.015000 Tip Radius=0.002500
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MGrassP] MWGrassP : 6004 Blades, Variable Points# per grass blade.
2016-08-17 09:48:31: 0: STDOUT: maxwell:[17/August/2016 09:48:31] [INFO]: [Extension MGrassP] Allocating grass data structures.
2016-08-17 09:48:32: 0: STDOUT: maxwell:[17/August/2016 09:48:32] [INFO]: Starting voxelization.
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]:
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Scene Info:
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Frame: 660
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Image output: N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.exr
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: MXI output: N:\renderfarm\Koala_Hospital\Render\Rendered_Frames\Right_Cam\Right_Cam.0660.mxi
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Geometry:
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Objects: 71
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Meshes: 61
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Triangles: 116984
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Vertexes: 61321
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Normals: 93735
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Num Materials: 14
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Camera: stereoCameraRight
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: Render settings:
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Engine version : 3.2.1.4
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Using RS1 engine
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Desired rendering time : 45
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Desired sampling level : 16.000000
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Using 8 threads
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Multilight type: Color + Intensity
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Save lights in separate files:No
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Motion blur: enabled
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Displacement: enabled
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Dispersion: enabled
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: - Illumination layers:
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . direct layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . indirect layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . direct caustic reflection layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . direct caustic refraction layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . indirect caustic reflection layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[INFO]: . . indirect caustic refraction layer: true
2016-08-17 09:48:32: 0: STDOUT: maxwell:[17/August/2016 09:48:32] [INFO]: Start Voxelization
2016-08-17 09:48:32: 0: STDOUT: maxwell:[17/August/2016 09:48:32] [INFO]: End Voxelization
2016-08-17 09:48:32: 0: STDOUT: maxwell:[17/August/2016 09:48:32] [INFO]: Voxelization done.
2016-08-17 09:48:37: 0: STDOUT: maxwell:[17/August/2016 09:48:37] [INFO]: Start Rendering
2016-08-17 09:48:37: 0: STDOUT: maxwell:[INFO]:
2016-08-17 09:48:42: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 09:48:46: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 09:48:48: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 09:48:54: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 09:48:54: 0: STDOUT: maxwell:[17/August/2016 09:48:53] [INFO]: Benchmark of 664.963. Time: 16m05s. SL of 12.45
2016-08-17 09:48:54: 0: STDOUT: maxwell:[17/August/2016 09:48:53] [INFO]: Time left: 44m46s
2016-08-17 09:57:16: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 09:57:20: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 09:57:22: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 09:57:28: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 09:57:28: 0: STDOUT: maxwell:[17/August/2016 09:57:28] [INFO]: Benchmark of 542.741. Time: 24m39s. SL of 13.00
2016-08-17 09:57:28: 0: STDOUT: maxwell:[17/August/2016 09:57:28] [INFO]: Time left: 36m12s
2016-08-17 10:06:22: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 10:06:26: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 10:06:28: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 10:06:34: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 10:06:34: 0: STDOUT: maxwell:[17/August/2016 10:06:34] [INFO]: Benchmark of 481.537. Time: 33m45s. SL of 13.48
2016-08-17 10:06:34: 0: STDOUT: maxwell:[17/August/2016 10:06:34] [INFO]: Time left: 27m06s
2016-08-17 10:18:27: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 10:18:31: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 10:18:33: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 10:18:39: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 10:18:39: 0: STDOUT: maxwell:[17/August/2016 10:18:39] [INFO]: Benchmark of 438.286. Time: 45m50s. SL of 14.00
2016-08-17 10:18:39: 0: STDOUT: maxwell:[17/August/2016 10:18:39] [INFO]: Time left: 15m01s
2016-08-17 10:30:23: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 10:30:28: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 10:30:29: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 10:30:35: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 10:30:35: 0: STDOUT: maxwell:[17/August/2016 10:30:35] [INFO]: Benchmark of 413.309. Time: 57m46s. SL of 14.42
2016-08-17 10:30:35: 0: STDOUT: maxwell:[17/August/2016 10:30:35] [INFO]: Time left: 3m05s
2016-08-17 10:33:27: 0: STDOUT: maxwell:[INFO]: Start writing MXI file...
2016-08-17 10:33:31: 0: STDOUT: maxwell:[INFO]: End writing MXI file...
2016-08-17 10:33:33: 0: STDOUT: maxwell:[INFO]: Start writing image file...
2016-08-17 10:33:39: 0: STDOUT: maxwell:[INFO]: End writing image file...
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Benchmark of 407.672. Time: 1h50s. SL of 14.52
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Ending render process..
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Render finished successfully
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Ending Session...
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Application cleaned. Closing sockets..
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Closing socket..
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Sockets closed. Processing events..
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Flushing events before closing...
2016-08-17 10:33:39: 0: STDOUT: maxwell:[17/August/2016 10:33:39] [INFO]: Exiting application...
2016-08-17 10:33:40: 0: INFO: Process exit code: 0
Details
Date: 08/17/2016 10:31:43
Frames: 660
Job Submit Date: 08/10/2016 23:14:27
Job User: dabend01
Average RAM Usage: 674968768 (16%)
Peak RAM Usage: 773287936 (19%)
Average CPU Usage: 98%
Peak CPU Usage: 100%
Used CPU Clocks: 60113804
Total CPU Clocks: 61340616
Slave Information
Slave Name: wci00210238dt02
Version: v7.1.2.1 R (53013d5bd)
Operating System: Windows 10 Enterprise
Running As Service: Yes
Machine User: deadlineservice
IP Address: XXX
MAC Address: XXX
CPU Architecture: x64
CPUs: 8
CPU Usage: 64%
Memory Usage: 2.0 GB / 4.0 GB (50%)
Free Disk Space: 1.364 TB (834.475 GB on C:\, 245.487 GB on D:\, 317.047 GB on F:\)
Video Card: Microsoft Basic Display Adapter
- By Edward Leibnitz
