By nirusu
#391925
Hi! I'm wondering if the "Visibility by Shader Tree" setting on an object in the Maxwell Plugin Window actually works and if so how?
I have tried to hide an object from Camera this way but without result... (tried base shader setting, tried item mask shader setting).
Currently the only way I see to hide something from Camera is to uncheck this first so the other options become available...
Cheers,
Nils
By Marton Day8
#391926
It works but it checks only the normal shaderTree shader (not the object shader).
In case it has multimaterials with different shaders, it calculates with the top most shader in the tree.
By Marton Day8
#391933
What is the question exactly:)?
Maybe it is more easier to set it directly (so not by shader tree), or you can add a shader to your emitter material and set hide from camera there.
Márton
