By lalllall
#391189
In Cinema you can export mxs for network render or rendering on a diffrent machine, you also have the pack and go option.
I have so far not found this function in modo and cant find it either in the program nor in the documentation.
Is there such an option? Or is the best way to start a render and stop it straight away?
The reason i dont want to use the network render is that you cant get the same instant feedback as if you are using maxwell
render
By Gloss
#391217
Hello,
as far as I know there is no direct pack&go feature in Modo. But you can still use it if you export an mxs (under file -> export as.)
After you saved your mxs, open Maxwell Studio, load the mxs, hit pack&go from there.
all the best
chris
