- Wed Apr 27, 2016 10:42 am
#390855
Hello,
I'm trying to create a heavy rainfall with the use of a particle emitter. (sphere with low poly's (12) However when I turn on object motion blur (value 3) in the scene properties panel, c4d crashes when hitting fire or the render button (R), when I use more then about 500 particles. Without the object motion blur there isn't any problem and I can add 10.000 particles easily. I must be doing something wrong, but I can't figure out what. I tried to switch off the "standard" motion blur in the scene properties as well as the motion blur in the C4D prefs (under physical tab). All to no avail. It looks like a lot of particles with object motion blur is a problem?
I use the latest MacOs, C4D (R17) and MR plugin
Cheers
Marc
Cheers
Marc
