By boerenkool
#390256
if it could generate maxwellrender instances.... :shock:
this would be a reason for me to renew my old licenses ;)
http://getskatter.com/
Your Skatter Production Can be Rendered by All Render Engines!
The “Render only” feature is currently supported by Thea, V-Ray, Corona, Twilight, Indigo, and Kerkythea. You can still use Skatter with any other render engine (Octane, Maxwell, Shaderlight, Podium, LightUp, etc), by actually generating the objects in the model.
By numerobis
#390257
You can use instances. The only thing that isn't supported with maxwell is the "render only" feature.
