All posts related to V3
By office@lutter.at
#390210
Hello,
I have a scene coming from archicad with the official plugin and many objects have a Multimaterial (little cube). Apparently nothing can be done from the plugin side so I am asking here:
How can I delete all those Multimaterials, I would like to have 1 Object = 1 Material. Is there a way to "flatten" the materials of an object ?
When I click on the little cube, i cannot do anything with the shown materials.
I cannot find any Info in the Documentation about these Multimaterials.
Thanks for your help,
Jonas
#390215
If you open the Attributes Panel and select one of these objects, you can scroll down to the Triangle Groups section; selecting all the triangle groups and hitting the Remove button will get rid of them, leaving only the material assigned at the object-level.
