By Hillmeister
#389999
Hi All,
A colleague gets the following message when exporting a scene from Rhino and trying to save:
Scene loaded successfully!
Number of Objects: 1280
Number of Triangles: 387417
Number of Materials: 14
Number of Cameras: 6
DO NOT SAVE MXI FILE flag enabled. MXI file will not be saved
DO NOT SAVE IMAGE FILE flag enabled. Image file will not be saved
Error saving scene: object.setNormal : Object is not created
Error saving scene: object.setTriangleUVW : No object defined to set triangle UVW
Error saving scene: object.setBaseAndPivot : No object defined to set base
Error saving scene: object.setPosition : No object defined to set Position
Error saving scene: object.setPivotPosition : No object defined to set Position
Error saving scene: object.setRotation : No object defined to set rotation
Error saving scene: object.setPivotRotation : No object defined to set rotation
Error saving scene: object.setScale : No object defined to set scale
Error saving scene: object.setShear : No object defined to set shear
Error saving scene: object.setUserData : Object is NULL
Error saving scene: writeMXS : Errors detected in scene creation phase. MXS will not be created.
It would be nice if someone can help him with that :)
He can't post on this forum somehow!?
#390000
That is not a known problem, so I'd need to see a 3DM by which I could reproduce it.
By Hillmeister
#390004
Hi Jeremy,
Can my colleague contact you directly by mail? I think he can better provide you with the things you need.
Thank you.
