- Fri Jan 08, 2016 12:11 am
#389857
Hello
i tried the last version with realflow scene and i have some notes :
- when i changed the shutter speed and click tab to switch to film iso case ; 3dsmax blocked
- i loaded animated texture created by realflow but i had a problem :
realflow by default export the name of the texture : name_001.ext ... name_00200.ext ...
with the plugin i choose : name_#.ext but it read only name like that : name__1.ext ...name__200.ext
so i need always rename the images sequence by : Bulk rename utility ; i can change export settings in realflow but i forgot that
- i can't add layer or bsdf ; always i need to duplicate
- we can't change nested priority for material assistant
- when exported a scene or animation : maxwell plugin exported also the perspective view ; sometimes was the active camera by default
- when i loaded bin mesh sequence and add mesh smooth modifier the plugin export only the first frame many time ; if i disable the smooth modifier it worked fine
- there is no option to hide object from camera
- no option for objects to modify smoothing like in studio
- By Matteo Villa
