By gawrondavid
#389313
Is is possible to animate the properties of a material. For example, animating the opacity or roughness?
Dave
#389314
Not of a Maxwell material, no. You can animate a Cinema material, and the required bitmaps and such will be exported per-frame.
By gawrondavid
#389316
How do I get the exported bitmaps? Do I need to convert the cinema material to maxwell? If so, where does it put the bitmap textures?
Dave
#389317
You don't need to convert the material, and it's important that you don't, because what happens is that while exporting each frame, the plugin will ask the Cinema shaders (whatever they may be) to render their bitmaps. The bitmaps will be labeled for the frame to which they belong, when they are written into the /textures directory, next to the MXS file. So, the materials in each frame will reference bitmaps written specifically for that frame.
#389318
And to answer your other question, it is on the radar, but not likely to happen soon.
By eric nixon
#389321
In case it helps, there is a kind of work-a-round where you animate the mapping coords for any given channel.
In this way you can animate a lot of things,.. probably using a b+w gradient map to control the roughness for example, then slide the (oversized) gradient left and right and the roughness will change at the spot where the map is passing through the geo.
