By ababak
#388464
Not to start a separate topic on RC1 I'll add my question here if you don't mind.
Does this version require a new Maya plugin again or the 3.2.4 version should work fine?
Thanks
By ababak
#388611
F.Tella wrote:Thank you for the bug report about tp_network executable.
tp_network is still unusable due to incorrect permissions. The bug has not been fixed in the release version.
By ababak
#388612
Here are the terminal commands to make them usable:
Code: Select all
sudo chmod +x /Applications/Maxwell\ 3/tp_network/tp_network_monitor.app/Contents/MacOS/launcher.osx
sudo chmod +x /Applications/Maxwell\ 3/tp_network/tp_network_manager.app/Contents/MacOS/launcher.osx
sudo chmod +x /Applications/Maxwell\ 3/tp_network/tp_network_node.app/Contents/MacOS/launcher.osx
