Everything related to SDK.
By ArmanZak
#388312
Code: Select all
#include <iostream>
#include "maxwell.h"
#include "mx_defines.h"
byte mx_error_callback(byte isError, const char *pMethod, const char *string, const void *data)
	if (isError)
		printf( "Error in Method  = %s \n error = %s  \n value = %d\n", pMethod, string, data );
	return (0);
int _tmain(int argc, _TCHAR* argv[])
	float vertices[12] = { -0.50f, 0.0f, 0.50f,	0.50f, 0.0f, 0.50f, 0.50f, 0.0f, -0.50f, -0.50f, 0.0f, -0.50f };
	float normals[12] = { 0.0f, 0.00998311397f, 0.0f, 0.0f, 0.00998311397f, 0.0f, 0.0f, 0.00998311397f, 0.0f, 0.0f, 0.00998311397f, 0.0f };
	dword trianglesV[6] = { 0, 3, 6, 0, 6, 9 };
	dword trianglesN[6] = { 0, 3, 6, 0, 6, 9 };
	Cmaxwell previewScene(mx_error_callback);
	previewScene.setAxisConversion("YXZ");
	previewScene.setSinglePrecisionOfGeometry();
	Cmaxwell::Cobject previewObject = previewScene.createMesh("mesh", 4, 4, 2, 1);
        /* method one start */
        for (int i = 0; i < 12; i+=3)
		int index = i / 3;
		std::cout << index << std::endl;
		previewObject.setVertex(index, 0, Cpoint(vertices[i], vertices[i + 1], vertices[i + 2]));
		previewObject.setNormal(index, 0, Cpoint(normals[i], normals[i + 1], normals[i + 2]));
	previewObject.setTriangle(0, 0, 1, 2, 0, 1, 2);
	previewObject.setTriangle(1, 0, 2, 3, 0, 2, 3);
         /* method one end*/
         /* two start */
	//previewObject.setVerticesBuffer(vertices, 3 * sizeof(float));
	//previewObject.setNormalsBuffer(normals, 3 * sizeof(float));
	//previewObject.setTrianglesBuffer(trianglesV, 3 * sizeof(dword));
	//previewObject.setTrianglesNormalsBuffer(trianglesN, 3 * sizeof(dword));
         /* two end */
	previewScene.writeMXS("E:/test.mxs");
	previewScene.freeGeometry();
	previewScene.freeScene();
	return 0;
I complie on Visual Studio 2013 v120,
use libs from maxwell 3.2.0 beta sdk libs for vc2013.
When I export simple plane with 4 vertices and 2 triangles, all works fine.
But when I use method two
In x64 I get crash one
Code: Select all
in win32 I don't have crash or any error message, but when I open exported .mxs maxwell studio crashed.
What wrong I do in method two?
By Brany
#388313
These indices are wrong. You have to index by vertex/normal, not by component:
Code: Select all
 dword trianglesV[6] = { 0, 1, 2, 0, 2, 3 };
dword trianglesN[6] = { 0, 1, 2, 0, 2, 3 };
