Everything related to SDK.
By ArmanZak
#388163
hi all.
Now i wotk on maxwell render plugin for daz studio.
In old maxwell sdk versions ( 3.0.0 and 3.1.0) all work properly.
But after changing mawell plugin sdk t version 3.2.0 compiler give this error
Error 1 error LNK1104: cannot open file 'libirc.lib'
I use Visual Studio 2013 Update 2.
Error comes for all compiler versions (vs2008, vs2010. vs2012, vs2013)
I googled and found tht libirc is part of intel c++ compiler.
What's happaning? I must use Intel C++ compiler for maxwell sdk 3.2.0??
After adding intel c++ compiler libs to my project libs, it's compile successfull, but daz studio plugin not working properly.
#388165
First, please make sure you are using an up-to-date copy of Visual Studio (for VS2013, that is update 5). If the issue persists, it may be necessary to add /NODEFAULTLIB:libirc.lib to the linker command line (i.e. Project > Properties > Configuration Properties > Linker > Input > Ignore Specific Default Libraries in Visual Studio). After ignoring libirc.lib, it may be possible that the linker will complain about some other Intel lib, in which case you would need to ignore that too, and so forth.
The reason for this is not yet known; the problem is that we do not currently have a test that successfully reproduces it, even though it has also been reported by one of our plugin developers.
By ArmanZak
#388166
Thanks for fast reply.
First my Visual Studio 2013 have all licensed update in last post in wrote wrong, it's Update 5.
After append libirc.lib in ignor lisy (a you wrote). prijject compiled correct without intel C++ compiler libs,
but plugin not loading in Daz Studio.
I think there something gone in bad way with maxwell sdk, because daz studio part is stay unchanged.
Again. In older versions of maxwell sdk (3.0.0 and 3.1.0) all work fine.
#388167
I can't really guess much about why it would not load; I'd start by checking that you are using the proper SDK build for your target CRT (v90/v100/etc), and then use VS or windbg to start the application and see what is or is not loading, and hopefully why. You might also check your binaries with dependency walker and reshacker, to see if there may be CRT mismatch issues.
Note that the .mxx extensions in MAXWELL3_ROOT are using v120 in the 3.2 builds, so if you are trying to load them from there, you would need to be using v120 (not v90 as it previously was).
By ArmanZak
#388174
For all CRT (v90,v100,v110,v120) same effect.
I run dazstudio with windbg and this is a part of log from my plugin and mxcommon
1f4c:20d8 @ 43338668 - LdrGetProcedureAddressEx - INFO: Locating procedure "getSDKVersion" by name
1f4c:20d8 @ 43338668 - LdrGetProcedureAddressEx - INFO: Locating procedure "getPluginDefinition" by name
1f4c:20d8 @ 43338668 - LdrLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Co
1f4c:20d8 @ 43338668 - LdrpLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\C
1f4c:20d8 @ 43338668 - LdrpLoadDll - INFO: Loading DLL C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll from path C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\
1f4c:20d8 @ 43338668 - LdrpFindOrMapDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x
1f4c:20d8 @ 43338668 - LdrpSearchPath - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338668 - LdrpResolveDllName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll
1f4c:20d8 @ 43338668 - LdrpResolveDllName - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338668 - LdrpSearchPath - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338668 - LdrpMapViewOfSection - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll
ModLoad: 000007fe`d61f0000 000007fe`d630e000 C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll
1f4c:20d8 @ 43338668 - LdrpMapViewOfSection - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338668 - LdrpFindOrMapDll - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338668 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll" imports "mxcommon_64.dll"
1f4c:20d8 @ 43338668 - LdrpLoadImportModule - ENTER: DLL name: mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\in
1f4c:20d8 @ 43338668 - LdrpFindOrMapDll - ENTER: DLL name: mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel6
1f4c:20d8 @ 43338668 - LdrpFindKnownDll - ENTER: DLL name: mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpFindKnownDll - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrpSearchPath - ENTER: DLL name: mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Windows\system32\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Windows\system\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Windows\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: .\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\ProgramData\Oracle\Java\javapath\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\imagemagick\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.5\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.5\libnvvp\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Python33\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Perl64\site\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Perl64\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\PC Connectivity Solution\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Windows\System32\Wbem\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Windows\System32\WindowsPowerShell\v1.0\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\TortoiseSVN\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\Microsoft SQL Server\110\Tools\Binn\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\Microsoft\Web Platform Installer\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Microsoft SDKs\TypeScript\1.0\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Ruby200-x64\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\nodejs\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\Git\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Users\Arman\AppData\Roaming\npm\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files (x86)\CMake\bin\mxcommon_64.dll
1f4c:20d8 @ 43338668 - LdrpSearchPath - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrpFindOrMapDll - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrpLoadImportModule - ERROR: Loading DLL mxcommon_64.dll from path C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\
1f4c:20d8 @ 43338668 - LdrpLoadImportModule - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrpHandleOneOldFormatImportDescriptor - ERROR: Loading "???????l??????????????????????" from the import table of DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll" failed with status 0xc0000135
1f4c:20d8 @ 43338668 - LdrpUnloadDll - INFO: Unmapping DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll"
1f4c:20d8 @ 43338668 - LdrpLoadDll - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrLoadDll - RETURN: Status: 0xc0000135
1f4c:20d8 @ 43338668 - LdrLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86
1f4c:20d8 @ 43338668 - LdrpLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x8
1f4c:20d8 @ 43338668 - LdrpLoadDll - INFO: Loading DLL C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll from path C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x
1f4c:20d8 @ 43338668 - LdrpFindOrMapDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program File
1f4c:20d8 @ 43338668 - LdrpSearchPath - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files
1f4c:20d8 @ 43338668 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\MaxwellPlugin.dll.dll
1f4c:20d8 @ 43338684 - LdrLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Comm
1f4c:20d8 @ 43338684 - LdrpLoadDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Com
1f4c:20d8 @ 43338684 - LdrpLoadDll - INFO: Loading DLL C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll from path C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Co
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86
1f4c:20d8 @ 43338684 - LdrpSearchPath - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\
1f4c:20d8 @ 43338684 - LdrpResolveFileName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll
1f4c:20d8 @ 43338684 - LdrpResolveFileName - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpResolveDllName - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll
1f4c:20d8 @ 43338684 - LdrpResolveDllName - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpSearchPath - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpMapViewOfSection - ENTER: DLL name: C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll
ModLoad: 000007fe`d55d0000 000007fe`d630c000 C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll
1f4c:20d8 @ 43338684 - LdrpMapViewOfSection - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "KERNEL32.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: KERNEL32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: KERNEL32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\c
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4d3 for procedure "TlsAlloc" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4d6 for procedure "TlsSetValue" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xec for procedure "DuplicateHandle" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1ca for procedure "GetCurrentThread" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1c6 for procedure "GetCurrentProcess" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4d5 for procedure "TlsGetValue" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x34a for procedure "LocalFree" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xc8 for procedure "DebugBreak" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2ca for procedure "GlobalSize" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2c2 for procedure "GlobalFree" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2bb for procedure "GlobalAlloc" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4e5 for procedure "UnmapViewOfFile" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x359 for procedure "MapViewOfFile" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x8c for procedure "CreateFileMappingW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1f7 for procedure "GetFileSize" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x474 for procedure "SetFilePointer" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x534 for procedure "WriteFile" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x3c3 for procedure "ReadFile" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x85 for procedure "CreateEventW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x467 for procedure "SetEvent" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x45a for procedure "SetCurrentDirectoryA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1c4 for procedure "GetCurrentDirectoryA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x3aa for procedure "QueryPerformanceFrequency" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1d4 for procedure "GetDiskFreeSpaceExA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x382 for procedure "OpenProcess" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2c8 for procedure "GlobalMemoryStatusEx" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2ac for procedure "GetVersionExW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x341 for procedure "LoadLibraryW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2c7 for procedure "GlobalMemoryStatus" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1c7 for procedure "GetCurrentProcessId" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x3a9 for procedure "QueryPerformanceCounter" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1fa for procedure "GetFileType" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x369 for procedure "MultiByteToWideChar" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2aa for procedure "GetVersion" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1cb for procedure "GetCurrentThreadId" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x7c for procedure "CreateDirectoryA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1f3 for procedure "GetFileInformationByHandle" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xa4 for procedure "CreateProcessA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x138 for procedure "FindFirstFileA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x149 for procedure "FindNextFileA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x134 for procedure "FindClose" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x208 for procedure "GetLastError" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x88 for procedure "CreateFileA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xe1 for procedure "DeviceIoControl" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2ad for procedure "GetVolumeInformationA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2ab for procedure "GetVersionExA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xee for procedure "EncodePointer" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlEncodePointer" by name
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xcb for procedure "DecodePointer" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlDecodePointer" by name
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xe2 for procedure "DisableThreadLibraryCalls" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4ce for procedure "TerminateProcess" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4e2 for procedure "UnhandledExceptionFilter" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4b3 for procedure "SetUnhandledExceptionFilter" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x302 for procedure "IsDebuggerPresent" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x426 for procedure "RtlVirtualUnwind" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x41f for procedure "RtlLookupFunctionEntry" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x418 for procedure "RtlCaptureContext" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x33e for procedure "LoadLibraryA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x163 for procedure "FormatMessageA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x219 for procedure "GetModuleFileNameA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4c0 for procedure "Sleep" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x520 for procedure "WideCharToMultiByte" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x4a2 for procedure "SetThreadIdealProcessor" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x49d for procedure "SetThreadAffinityMask" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x24c for procedure "GetProcAddress" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x2ea for procedure "InitializeCriticalSection" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlInitializeCriticalSection" by name
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x21b for procedure "GetModuleHandleA" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xd2 for procedure "DeleteCriticalSection" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlDeleteCriticalSection" by name
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x3fd for procedure "ReleaseMutex" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x9e for procedure "CreateMutexW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xae for procedure "CreateSemaphoreW" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x508 for procedure "WaitForSingleObject" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x52 for procedure "CloseHandle" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x401 for procedure "ReleaseSemaphore" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x33b for procedure "LeaveCriticalSection" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlLeaveCriticalSection" by name
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x168 for procedure "FreeLibrary" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0xf2 for procedure "EnterCriticalSection" in DLL "KERNEL32.dll" is invalid
1f4c:20d8 @ 43338684 - LdrGetProcedureAddressEx - INFO: Locating procedure "RtlEnterCriticalSection" by name
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "SHELL32.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: SHELL32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel6
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: SHELL32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\co
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "iphlpapi.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: iphlpapi.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: iphlpapi.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\c
1f4c:20d8 @ 43338684 - LdrpSnapThunk - WARNING: Hint index 0x1c for procedure "GetAdaptersInfo" in DLL "iphlpapi.dll" is invalid
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "MSVCP100.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: MSVCP100.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: MSVCP100.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\c
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "MSVCR100.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: MSVCR100.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: MSVCR100.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\c
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "WS2_32.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: WS2_32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: WS2_32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\com
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "PSAPI.DLL"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: PSAPI.DLL DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: PSAPI.DLL DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\comp
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "USER32.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: USER32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: USER32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\com
1f4c:20d8 @ 43338684 - LdrpHandleOneOldFormatImportDescriptor - INFO: DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll" imports "ADVAPI32.dll"
1f4c:20d8 @ 43338684 - LdrpLoadImportModule - ENTER: DLL name: ADVAPI32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel
1f4c:20d8 @ 43338684 - LdrpFindOrMapDll - ENTER: DLL name: ADVAPI32.dll DLL path: C:\Program Files\DAZ 3D\DAZStudio4;C:\Windows\system32;C:\Windows\system;C:\Windows;.;C:\Program Files (x86)\Windows Kits\8.1\Debuggers\x64\winext\arcade;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\c
1f4c:20d8 @ 43338684 - LdrpUpdateLoadCount2 - INFO: Referencing loaded DLL "C:\Windows\system32\PSAPI.DLL" (new reference count: 0x4)
1f4c:20d8 @ 43338684 - LdrpUpdateLoadCount2 - INFO: Referencing loaded DLL "C:\Windows\system32\Iphlpapi.DLL" (new reference count: 0x4)
1f4c:20d8 @ 43338684 - LdrpUpdateLoadCount2 - INFO: Referencing loaded DLL "C:\Windows\system32\WINNSI.DLL" (new reference count: 0x4)
1f4c:20d8 @ 43338684 - LdrpRunInitializeRoutines - INFO: Calling init routine 000007FED5C5578C for DLL "C:\Program Files\DAZ 3D\DAZStudio4\plugins\Maxwell\mxcommon_64.dll"
1f4c:20d8 @ 43338700 - LdrpLoadDll - RETURN: Status: 0x00000000
1f4c:20d8 @ 43338700 - LdrLoadDll - RETURN: Status: 0x00000000
#388179
Again, I can't tell you much. However, we can break down your output. First, the system tries to load plugins\Maxwell\MaxwellPlugin.dll:
Code: Select all
plugins\Maxwell\MaxwellPlugin.dll is found and would load, but cannot, because the system is unable to find mxcommon_64.dll (0xc0000135 is STATUS_DLL_NOT_FOUND). Since plugins\Maxwell\MaxwellPlugin.dll failed, the system tries to load plugins\Maxwell\MaxwellPlugin.dll.dll, which does not exist:
Code: Select all
Of course this fails. Last, for some reason I do not know, the system tries to load plugins\Maxwell\mxcommon_64.dll:
Code: Select all
I am not sure about those LdrpSnapThunk warnings, but the dll (it is the v100 build) loads successfully. So if I were to guess, if you moved mxcommon_64.dll directly into the DAZStudio4 directory (or any of the many directories we see being searched in the first phase), the system would find mxcommon_64.dll, and your plugin would load. However, I do not know which CRT DAZ Studio uses, so that is not a guarantee -- you cannot use just any CRT, you must use the same one that the host application's SDK uses.
