- Tue Aug 18, 2015 1:04 am
#387707
I am trying to apply a scatter extension in the Rhino plug in and am coming up against an issue.
In the Rhino plug-in the only option for defining the object to scatter is uploading an mxs file:
In Maxwell studio it allows you to upload or select within the file any type object:
Why is this? Am I overlooking a window or tab to select and upload other objects to Rhino? Also, is it possible to use control points in Rhino to define the density of the scatter or do I need to use a density map?
Many thanks,
Andrew
Many thanks,
Andrew
- By Matteo Villa
