- Wed Jul 22, 2015 12:03 pm
#387504
This is not related to Maxwell plugin. The file node is not only a file name, but also a texture placement information (such as tiling, wrapping, mirror), image controls (invert, brightness, contrast, RGB max, etc), UV channel selection.
You may use a Hypershade editor to link one file node to several inputs if you don't need to change any parameters I mentioned earlier. As for me, this just helps to organise a scene and makes replacing a texture a bit shorter operation. I doubt that extra file nodes should take much RAM so in most cases I just don't bother.
Regards,
Andrey Babak
WIP | Gallery | Blog
