By Marton Day8
#386553
When you select the light, on the Maxwell panel you should see the switch "Hidden for Refl/Refr". This option desn't make it visible for camera but only for reflection and refraction.
Do you need full visibility?
Márton
By Tea_Bag
#386557
Hi Marton,
Yes full visibility it what I was after and from what I can see this can only be made visible through studio. I have now placed a plane as an emitter instead as its only
a light source from a window. :)
edit hmm..just so you know I'm not seeing the "Hidden for Refl/Refr" in the Maxwell panel within the plugin.
