By macray
#40310
just start maxwell from the startmenu, load a picture.... have fun.
By ludenhud
#40312
just look in threads in this section of the forum and you will find several posts about how to use mxi.
Atilla.....
1. Open mxi viewer
2. From the "File" menu >Load image
3. Load a bitmap (jpg, tga)
4. Adjust the intensity of the image using the intensity slider until you get the brightness you want. Brighter=it will cast more light when used as an emitter.
5. File>Save mxi
6. In Max, make a Maxwell emitter material.
7. In the mxi texture slot click on it, from the menu that comes up, click Mxi loader, and load your mxi texture.
You cannot convert HDR images directly to mxi with the mxi viewer for now, you have to first convert your HDR images to LDR (jpg, tga etc), then convert those to mxi.
There have already been 15-20 posts about this in both this forum and the gallery. Please take the time to read through them, then, if you have further questions.....
By DELETED
#40343
DELETED
